![]() Drives: Yaris 1.3 2010 Join Date: Aug 2022
Break fluid change anything required for clutch?
Dear all,
Break fluid is due, I'm going to replace it. I believe the same reservoir is used for the clutch. Is there any additional step in order to also replace the fluid from the clutch? I have a vacuum pump, can I do the same as with the breaks? Yaris 2010 1.3 Last edited by moozart; 08-12-2022 at 04:16 PM. |
![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Maybe gravity bleed the clutch master cylinder.
Bleed the clutch slave exactly as you would the brakes. There is no need to pull a vacuum but if you want to be my guest.
If you think about it your clutch is used 10 times more than the brakes. Every year it should be bled. If the transmission is not shifting properly and you haven’t bled the clutchs in 10 years DO THAT FIRST
Thread Tools | |
Display Modes | |
MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 03:20 PM |
AT fluid change interval? | Yaris_Fan | DIY / Maintenance / Service | 11 | 06-04-2007 12:57 AM |
2007 LB Yaris - AT - Fluid Change Interval | Pavel Olavich | DIY / Maintenance / Service | 9 | 03-21-2007 07:09 PM |
Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 11:57 PM |
soo whos gonna change their tranny fluid | twixt | DIY / Maintenance / Service | 0 | 08-04-2006 04:09 AM |
