Old 03-06-2021, 03:30 PM   #1
TS Turbo
Drives: 2005 Yaris TS Turbo 1NZ-FTE
2005 TS Yaris fuel pump?
Hi!
First post on this forum so hello to you all :)
I have a 2005 Yaris TS Turbo. This is as far as I know the European version of the Vitz. ***might be wrong here as you see further down***
During the really cold winter here in Norway my fuel pump died. So I was wondering if anyone knows if it is the same fuel pump in a TS turbo as in a Vitz? I have tried searching for this but it is quite hard to figure out. The engine code for my car is 1NZ-FTE and for a Vitz it is 1NZ-FT. The E at the end might just be "Europe" but I don't really know.
Does anyone know the difference between them, if any at all? Maybe even know what pump fits the TS turbo? Is the pump labelled so I can just take it out and search for it perhaps? Any tips is appreciated :)
And just for fun - is it possible to fit a more powerful pump and get a benefit without more modifications to accommodate the increased fuel flow?
Edit: Should probably add my diagnosis:
-The car had been sitting for several months in 0 degree fahrenheit/-20 celsius weather.
-The tank was 3 quarters full
-Battery was completely dead
-Hooked up another good battery
-Car cranks strong but no sign of detonation
-Can't hear hum of pump when turning on ignition, but can hear the relay click
-Checked a spark plug and it was dry even after a lot of cranking
After looking at pictures of the Vitz I'm not sure they are the same car at all - This is how mine looks
TS Turbo is offline   Reply With Quote
Old 03-06-2021, 04:29 PM   #2
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
https://en.wikipedia.org/wiki/Toyota_Vitz
Read under XP10 Asia Market P2 Vitz RS. Your model should be the NCP13 for JDM.
1NZ-FE is the engine code. Yours have the additional T for Turbo. Might be best to remove your fuel pump and check the part number before you purchase a replacement:
https://www.ebay.com/itm/Fuel-Pump-f...8AAOSwuwRYLeii
Fluxtasy is offline   Reply With Quote
Old 03-07-2021, 10:43 AM   #3
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Cant you find the part number here.
http://www.japan-parts.eu/
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 03-07-2021, 12:27 PM   #4
TS Turbo
Thanks to both of you for your reply.
Found the part to be 23220p. Does anyone know where to find this part cheap? Or does a fuel pump alone really cost 300-450usd?
Does anyone know if this car has a Fuel Pump Safety Pressure Switch? Or any Yaris for that matter?
Old 03-07-2021, 01:45 PM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
that sounds awfully high
I don't think there's a safety switch. Like all Yaris/Vitz, you need to remove the rear seat to access the fuel pump.
Old 03-08-2021, 12:00 PM   #6
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Same pump as the regular T-Sport.
Also the enginecode is 1NZ-FE(T) Where the T stands for Turbo which was added later on, The rest of the engine is the same as regular 1nz-fe
These ecu's are locked so fitting a bigger bump is useless
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
will a prisus fuel pump work in a yaris jens07yaris DIY / Maintenance / Service 9 08-12-2012 01:08 PM
dose the yaris LB have a fuel pump? Moses DIY / Maintenance / Service 12 05-28-2010 08:40 AM
