Old 02-01-2021, 12:05 PM   #1
Neinris
Speed Accuracy...
The Yaris is said to have two different stock wheel/tire combo, the 175/65/R14s and 185/60/R15s. Currently I have 185/60/R15s, and my speedometer reading is off by 2MPH, where it reads 60MPH, when I'm actually going 62MPH. So I believe my car is dialed for the 175/65/R14 combo. It's kind of bothering me and want it fixed. Am I the only one having this issue? I don't want to go with smaller tires because currently the tire size I have fill my wheel well nicely. Is there a part number difference for the speed sensor that goes in the transmission?
Old 02-02-2021, 12:08 PM   #2
Mister
Drives: Yaris T1
https://yellr.com/
Yootoobers use this?
Mister is offline   Reply With Quote
Old 02-02-2021, 05:28 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Hmm, my speedometer reads faster that the actual speed.
Interestingly, If I take the output from the OBD port, it agrees with GPS speed. I wonder if anyone knows if it is possible to physically open the speedometer and adjust it?
Old 02-03-2021, 11:07 AM   #4
Neinris
Originally Posted by Mister View Post
https://yellr.com/
Interesting... Thank you! I might get this.
Old 04-30-2022, 01:21 PM   #5
RedRide
RedRide's Avatar
With my '09 HB The speedometer is dead on
This is according to all those solar powered speed read outs that a lot of towns use.
When a readout says 30 MPH (in a 30 MPH zone) that is exactly what my speedometer says also.
This is with 185/60/R15s tires as this is the size that came with it
Old 10-13-2022, 05:11 PM   #6
Neinris
Eureka!!!
I discovered that there ARE two different part numbers for the speedometer driven gear sun-assembly!!!
One specifically states 185/60R15, I’m going to order it and install and see if that fixes my speed difference issue that’s bee driving me nuts for years!!!
File Type: jpg 02029CF9-F26D-44DC-93A1-D4C3DDB94E91.jpg (86.8 KB, 40 views)
Old 11-02-2022, 08:58 AM   #7
Neinris
Is there a special tool to remove the speed sensor that's in the manual transmission? I couldn't get mine off to try and replace the gear sub-assembly. And yes, I removed the bolt that was holding it.
Old 11-02-2022, 12:38 PM   #8
sh0rtlife
assuming its like all the rest ..its a very..VERY tight fit and just needs more effort..alot of them are a neer press on fit, you could always try tossing it in the freeze for a couple hours to shrink the metal its on
Old 11-02-2022, 03:18 PM   #9
remcafee
it should be sealed by an o ring, sometimes they fuse themselves to the case, just keep struggling, swearing, and fucking up your hands until its out lol
Old 11-02-2022, 04:08 PM   #10
Neinris
LOL!!!
Old 11-02-2022, 04:44 PM   #11
sh0rtlife
ah the actual sensor..is there room to get a carpenters blade under it?..ive used them as a puttyknife on things like that in the past to work them up just enought o actuly get a puttknife in there to work them more
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 304 10-10-2023 05:23 AM
Question on Radiator/AC Condenser fan speed rayfloyd170 Third Gen Yaris General Discussion 3 08-11-2020 07:44 PM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
