08-20-2024, 11:17 PM | #1 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Hub Removal for Wheel Bearing or ABS Sensor - The Easy Way
Take a bolt and nut. Push the bolt through a hole in the hub and thread a nut on the other side. Jack the hub off the backing plate and axle/knuckle.
https://youtu.be/kxB9xCZ-w5Q?si=383D_-3WqNW-aeUW |
08-29-2024, 05:26 AM | #2 |
This is the process I used to remove the bearings when I had to replace my rear beam. It works.
If you want to enjoy your car, stay off of the internet. |
09-05-2024, 05:49 PM | #3 |
This is also for doing rear ABS/wheel speed/skid sensors which are lightly pressed on the back of the hub bearing, and they require the hub to be completely removed first.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
yaris hub and bearing assy with abs | chrissy b | Items for Sale by private party | 8 | 12-12-2011 09:22 AM |
for sale yaris and yaris verso hub and bearing assy | chrissy b | Items for Sale by private party | 0 | 04-07-2010 06:52 PM |
for sale yaris hub and bearing assy all models | chrissy b | Items for Sale by private party | 0 | 03-31-2010 08:21 AM |
for sale yaris hub and bearing assy all models | chrissy b | UK | 0 | 03-26-2010 09:56 AM |
