Old 10-28-2020, 12:38 PM   #1
bronsin
bronsin's Avatar
Anybody use a dipstick oil sucker?
My brother is sending me a 12 V oil sucker that removes oil through the dipstick hole
Does anybody have any experience and advice on using one of those?
Thanks!
Old 10-28-2020, 02:55 PM   #2
bronsin
bronsin's Avatar
https://www.amazon.com/Extractor-Sca.../dp/B07X33FC1V
Old 10-28-2020, 06:47 PM   #3
ex-x-fire
I have but not on a yaris, it works well if you have a large diameter dipstick tube and the oil is hot. I'd like to tap a hole in the pan for a 3/8 tube, the lower oil pan is easy to remove.
Old 10-28-2020, 11:55 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Why not jack up the car and use the drain bolt? You are talking about motor oil, right, and not ATF? I have one of those pumps. It works great, but I basically use it for pumping oil into my rocker panels.
Old 10-29-2020, 02:39 AM   #5
bronsin
bronsin's Avatar
I have Parkinson’s and my brother thought this would be easier for me. There actually are cars you can change the oil filter without getting underneath. I don’t suppose I will use it on my Corolla but it would be great For my craftsman garden tractor which has a very complicated drain valve.
Old 10-29-2020, 05:58 AM   #6
06YarisRS
It would definitely be easier. I think you'll be pleased with the pump. They do work quite well.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
