#19 |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
DAMN! I'm jelly... you even did the 5th gear swap that I had planned on doing. Where'd you get them headlights!!!
#20 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
They look like projector retrofitted OEM lights.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's ![]() |
#21 |
#22 |
![]() Drives: '07 Yaris Liftback Join Date: Jul 2007
Yup! Morimoto M LED 2.0 projectors in the stock housing. Wanted that OEM+ look
#23 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
was the differential preload in spec? or did you have to change out the shim? im curious as to how to remove the bearings in the case
#24 | |
Unless you have a very large press, I used a deadblow with an appropriately sized socket to push the old bearings out. |
#25 |
gotcha gotcha, did you also fp the input shaft bearing and that front seal?
#26 |
Thread Tools | |
Display Modes | |
Toyota Echo Trans Swap (Auto -> Man) | es604 | Performance Modifications | 2 | 07-29-2022 09:03 PM |
Manual To Auto | bronsin | General Yaris / Vitz Discussion | 10 | 12-22-2008 11:32 PM |
Manual vs. Auto | littlecarlove | General Yaris / Vitz Discussion | 25 | 10-25-2006 09:45 PM |
