Old 11-08-2010, 02:30 PM   #1
karozzeria
Drives: yaris 07 hb
Exclamation 07 hatchback strange noise
As I go round corners / bends at very slow speeds my yaris gives an abnormal noise. It sounds like something dragging. It only happens when I turn the steering and drive slowly. If I drive at an equally slow speed but straight ahead i hear no such noise. What could it be?? Thanks
karozzeria is offline   Reply With Quote
Old 11-08-2010, 03:44 PM   #2
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Old 11-09-2010, 07:35 PM   #3
woof
Drives: Yaris 3dr Hatch/Black
My '07 Hatch does it when I turn left with stock wheels and tires. i'm thinking the electric steering might be howling for some odd reason.
woof is offline   Reply With Quote
Old 11-10-2010, 12:44 AM   #4
yaris2010RS
yaris2010RS's Avatar
is it stock springs? my coilovers make stupid sounds when i turn at slow speed (the rubber top cap) get a car of WD40 and spray up into the wheel well and try to get it on the top of the top coil/top of the shock tower and see if that helps, thats what i do and im good for another few weeks.
only do the wd40 thing after checking to ensure no loose plastic is rubbing the tires.
Old 11-10-2010, 02:29 PM   #5
karozzeria
Drives: yaris 07 hb
hmm...thanks for your replies, will keep you posted with what happens to it. Actually the noise is a kind of whine I think.
Old 11-10-2010, 02:34 PM   #6
karozzeria
Drives: yaris 07 hb
mm...but then, why would it only happen at slow speeds, less than 60 km
Old 11-10-2010, 02:49 PM   #7
severous01
wheel bearing??? cv joint??? check them out...but it's prob not a joint if you dont get a pop.
Old 11-10-2010, 10:22 PM   #8
yaris2010RS
my vote is the shock tower. if not maybe the steering shaft. my moms 01 camry has this issue, every 10,000km it needs grease on the universal joint (under the dash)
is the sound only when in a turn or while turing the steering wheel?
Old 11-10-2010, 11:14 PM   #9
tires too tall/wide?
Old 11-11-2010, 02:53 PM   #10
karozzeria
Drives: yaris 07 hb
yes only at turns to the right. (it's right hand drive)
Old 11-13-2010, 09:23 AM   #11
karozzeria
Drives: yaris 07 hb
Took it to the mechanic. Said there are some plates rubbing.
Tags
'07, braking, noise, steering
strange noise elmo DIY / Maintenance / Service 6 11-22-2010 07:00 AM
Strange noise! mario98c Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-24-2010 05:49 PM
strange noise before the car stops dani1983 DIY / Maintenance / Service 14 08-15-2009 11:56 AM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 08:37 PM
strange noise nisyota DIY / Maintenance / Service 7 03-05-2009 08:39 PM
