03-11-2023, 05:42 PM | #1 |
Drives: 2006 Yaris Join Date: Nov 2020
Trying to figure out new wheels
Hey y'all.
I got a 06 5dr hatch lowered on this bilstein kit. https://t1motorsports.ca/products/bi...suspension-kit Been hummin and hawing about new wheels. Worried about rubbing but I think I'm being too cautious. Would a 15x6.5 +35 offset with maybe a 195/55r15 on it be safe? Mostly concerned about the poke. Here's some pics how it's sitting in the front on 175/65r14x5.5 +46. Thanks! |
03-11-2023, 10:59 PM | #2 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
flush fitment would be 16x7 +35, so your 6.5 would be tucked in
03-13-2023, 03:18 AM | #3 |
Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
I run r15195/50 with et32 rubs a tiny bit iner guard when parking as I think I need a 3mm spacer bbut otherwise love em.
03-13-2023, 12:25 PM | #4 | |
Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
https://www.youtube.com/watch?v=XieYsLZgYjY |
03-13-2023, 01:47 PM | #5 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
i run 195/50/14s no issue, my snow tires are 205 50 15 on XB wheels which is a tad more offset than stock and no rub from either
imo if you get good tires you dont need to go wider than a 195 or 205 anything wider is just going to hurt the fact that youve got little torque to work with in the first place...and try and stick with light wheels |
03-13-2023, 02:57 PM | #6 |
I wanted to go 5X114.3 PCD to put the R32 GTR wheels (16X8 et+30), but I think I'd just go with some CP22 still 5X114.3 PCD, but they're 16X7 et+35. Yeah they have them in 4X100, but they just don't look right.
03-16-2023, 01:26 PM | #7 |
Ended up biting the bullet and got some avid1 av-08s with 195/55r15 yokohama advan flevas! Very Excited to see how it looks, thanks guys.
Gonna be a bit taller of a setup but I dont think it should rub and I got some camber bolts that should make it safe. |
03-17-2023, 10:11 AM | #8 | |
I was going to say don't worry too much with the 195/55R15 tires being a bit taller. One of the OEM wheel/tire combo is 185/60R15, which is taller than what you picked, but would make you go faster (about 2MPH) than what's indicated by your speedometer if your speedometer is dialed for 175/65R14. |
03-17-2023, 10:58 AM | #9 | |
Thanks! I'm not too fussy about that kinda stuff |
03-18-2023, 01:49 PM | #10 |
there is always a bit of "wiggle" in a speedo acuracy to make up for slight changes in tire size so dont stress it....mine came with the stock tall skinny 14s..terrifying tires lol
having worked tires for a good while...i can tell you that +/- 1 inch of tire is small enough to not even notice a change in speedo..and in alot of cases 2 inches is still within spec, once you get outside that you WILL see changes...as those changes are more noticed at speeds above 60mph |
03-18-2023, 02:03 PM | #11 |
My car is dialed for the 175/65R14 tires, and I have 185/60R15 tires, which makes my speedometer inaccurate, I'm actually going 62MPH when me speedo is reading 60MPH. I bought a different speed sensor gear, which is supposedly for the bigger tires, but it's a PITA to get off the transmission.
I got a HUD from my Brother-in-law for Christmas, and I'm happy with it, because now I have a tachometer as well as an accurate speedo. |
03-19-2023, 02:34 PM | #12 |
i feel like the "tach equiped" dashes stay more acurate with tire changes somehow....you need to swap your dash!!!
03-20-2023, 02:38 PM | #13 |
03-20-2023, 09:30 PM | #14 |
Similar Threads | ||||
FS: Mini Cooper 5 Spoke Wheels with Tires, Hubcentric Rings and Lug Nuts | CTScott | Items for Sale by private party | 14 | 08-17-2012 11:18 PM |
When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
FS: 15x7" Advan Kreuzer xii Wheels - New - Various - Cheap | jtf1986 | Items for Sale by private party | 21 | 08-15-2011 02:30 PM |
JDM Wheels and some track wheels/tires | jdmekcivic | Items for Sale by private party | 10 | 09-08-2009 12:27 PM |
forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
