![]() Drives: 2001 Vitz RS Join Date: Dec 2021
Tired engine? 2001 Vitz RS
Hey.
I've got a well used 2001 Vitz RS that i bought for cheap a few years back (exterior in rough looking condition, paint/clearcoat coming off, front bumper damage, wheel coating eaten away by something etc etc) and it had high km's when i bought it (305,000km/s, now up to 335,000km/s). The first things we did were replace all the spark plugs (to decent ones, not the cheapest available), replaced air filter, changed oil and oil filter plus a couple other things. Since then we've also replaced the fuel filter, and have done multiple oil changes in the past 30k km's too. We've changed it to thicker oil recently to try stop it from going through so much (needed to keep topping it up, more than both my other cars combined). Started using 10w/30 synthetic (?) and now using 10w/40 semi-synthetic. It seems to have mostly curbed the excessive oil use. But the main reason for this post is to hopefully get some sort of idea what is causing the tired feeling engine. Basically the symptoms are; - A grinding/mechanical type sound when putting decent load on when accelerating (half throttle or more). I've driven many cars (albeit with lower k's), and it's not a common sound. It's quite quiet, you can't hear it with windows down or radio on, but it's there. - Inconsistent power delivery. Sometimes it's sluggish power delivery (with little surges thru the rev range, like it's turbocharged etc), and sometimes it's really zippy and rev happy. It still seems to be random and not really caused by anything in my control? Like i can floor it in second gear one minute and it's nice and smooth and linier, the next time it'll be "nothing-nothing-nothing-POWEEEEER-less power-POWEEEER" etc. Basically it feels a bit like my turbo Nissan, but with less of a kick when the turbo kicks in. - The aforementioned oil burning issue, for which our mechanic suggested thicker oil. Firstly, i know i shouldn't expect much from an engine with such high km's, and no idea how it's been looked after by previous owners, but basically i'm hoping to find out the possible reasons for its inconsistent power delivery and roughish sounding noises when under heavy throttle. I very nearly bought a 150k engine the other month, but opted not to only because the car is still reliable (*touch wood*) and wasn't sure if fixing this power problem would be an easy fix, or an engine rebuild. If the latter, it's significantly cheaper to just chuck another engine in it ($8,000NZD+ rebuild compared to $2,000 NZ incl. engine). At the end of the day it's just my daily driver and our road trip/gravel road car, so it needs to be reliable. Which is why i wasn't bothered about the exterior condition, as it's good for parking in supermarket car parks where no-one cares about opening doors into other cars. It is a tough wee car though, and it loves gravel roads and other such adventures. It's a very fun car to drive despite the low power, and the interior is in quite good condition surprisingly (aside from wear and tear on gear stick and steering wheel), which is why i intend to ignore my mechanic's advice to scrap metal the car when the engine dies. Anyway. Would be good to know if i should fix it or just do an engine swap or not if another one in the 100,000km range pops up for sale again. Cheers. |
Gen 3 > Gen 2
Drives: 2014 LE, 2007 F150 Join Date: Jul 2019
I'd run it till it spills its guts all over the road. 1NZ-FEs are dirt cheap here.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed ![]() |
#3 | |
Sorry for the thread bump.
So my mechanic said that the power probs i mentioned (below) could be due to old/worn injectors. He suggested a second hand set (fitted for $275NZD or so), as new ones are $175NZD brand new, each. Has anyone had a similar power prob that was fixed with new/replacement injectors? Quote:
![]() ![]() ![]() Drives: 2007 5dr canadian import Join Date: Dec 2016
injectors would make the most sense, seconded by anything controling the fuel curve IE maf, ecu, o2....and things dont have to be throwing codes to be bad enough to cause an issue
bumping your own thread is a GOOD thing..gives us the back story we need |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
I just bought an injector tester which is just a pulsing timer to activate the injectors, I got it to back-flow and clean the injectors on my 1nzfe but turns out a third of my gas is water and ethanol that is no longer suspended with the rest of the fuel. 25 dollars to have a tool to clean injectors indefinitely until they stop working or the pintle gets too worn and leaks is a pretty cool deal in my opinion. I might make a lil flow bench with a poopy fuel pump, fuel hose, and some graduated cylinders, highly recommend you do that route too before you go guessing with a mechanic and expensive injectors. I have 350k miles with no issues so far and with my fuel being constantly mixed with old debris and water, so I doubt your injectors are done already, they might just need cleaning
Thread Tools | |
Display Modes | |
2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 11:56 AM |
engine shot from the vitz GRMN test car | enviri | Third Gen Yaris General Discussion | 10 | 01-30-2018 11:51 AM |
Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
A German Yaris/Vitz/Echo ;) | we-to-11 | Photo-Video-Media Gallery | 5 | 06-27-2007 08:26 PM |
