Old 06-09-2020, 06:01 PM   #1
remcafee
Exhaust spring bolts
Are the spring bolts needed in our exhaust setup? for 07 hatch my dc sport header, magnaflow catalytic converter pipe and fujitsubo muffler all wont work with spring bolts and need longer threads, is it ok to put staright bolts with nuts? or are the springs necessary? anyone let me know what your solution was with aftermarket exhaust will be much appreciated, thank you.
Old 06-10-2020, 02:11 PM   #2
Spring bolts serve two purposes. The first is to draw the flanges in to create a perfect seal as the gasket slightly melts itself into place. The second is to keep the joint drawn tight as the gasket slowly corrodes with age.
Old 06-10-2020, 02:31 PM   #3
Zedicus
Drives: scion xb
a lot of times you can just get different length bolts and still use the OEM springs and washes, due to the flange thickness on aftermarket exhausts.
other things i have done include:
using springs from a motorcycle clutch.
cutting the factory sprint in half and using half on each side (severe clearance issues from a knockoff exhaust kit)
cutting the factory flange off and welding it to the new exhaust.
changing out the OEM manifold to a header that used a flat flange or a V-band clamp.
Zedicus is offline   Reply With Quote
Old 06-10-2020, 03:05 PM   #4
remcafee
ok so what if i cut the thread in half on the oem bolt so it clears the primary o2 sensor? but then that would leave the spring all the way compressed and not really do anything right?
Old 06-10-2020, 03:17 PM   #5
How much more thread do you need? You could purchase the aftermarket spring bolts that use a spacer sleeve rather than integrated shoulders. Just cut the sleeve to a shorter length, or use the sleeve and spring on separately purchased longer bolts. A fully compressed spring is still applying pressure which is what you want. A spring that is not, or minimally compressed is doing nothing.
Old 08-29-2022, 06:13 AM   #6
AlaynaMichael
AlaynaMichael's Avatar
Drives: bmw
Is it possible to replace the springs with something?
AlaynaMichael is offline   Reply With Quote
Old 08-29-2022, 06:17 AM   #7
jonishornung
Drives: bmw
Spring bolts are necessary for the exhaust system because every element is very important in this system. For example, imagine that in your sewer system, there is a clog in one of the pipes, then the whole system would stop functioning. And to solve the problem, you would have to use hydro jet drain cleaning yorba linda. I recently encountered a clog that made it impossible to wash. But I managed to find a company that deals with sewer cleaning, and I turned to them for help.
jonishornung is offline   Reply With Quote
Micro Image center exhaust... tooter Performance Modifications 64 10-14-2012 11:07 PM
exhaust help naossoan Performance Modifications 6 09-24-2011 02:06 PM
Spring bolts torque specifications? Taiyaki Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 06-18-2009 05:39 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
