Old 10-07-2019, 04:36 PM   #1
Highball116
Drives: 2009 Honda Civic
Body work on prospective Yaris
Hi Everyone,
My sister is going to replace her Yaris soon and I was thinking about taking it off her hands. I don't know the year, but I would guess it's about 10 years old, and it's a two-door hatchback. The thing is, it has a lot of rust on the rear of the rocker panels and the rear wheel wells. Are there panels out there to cut and weld in?
Anything else I should watch for?
Thanks!
Toby
Highball116 is offline   Reply With Quote
Old 10-08-2019, 06:11 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
There is a video here in which a guy fixes the areas to which you refer. One area that does tend to go bad is the unibody section just underneath and forward of the rear wheels. There is a small dogbone shaped stiffener that attaches in 2 spots. The contact points tend to rot out. Many Yari are scrapped as apparently it is expensive to fix. That said, anything can be fixed with time, patience and $$.
Prospective new Yaris owner Frank Necrosis New YARIS Purchase Forum 7 06-05-2012 08:38 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
