Old 05-11-2021, 10:01 AM   #1
KermitAUS
Drives: Yaris 2009
Which specific OBD II (auto off) to use for a Yaris 2009 1.3L?
OBD-II (ELM-327) Bluetooth Dongle that is small & will auto shut-off
I want to leave my OBD-II dongle connected all the time.
Can anyone suggest an OBD-II bluetooth dongle that is small, works with my 2009 yaris and will power down after the car is turned off?
I can use an extender cable to hide the sensor if needed, but smaller is better.
Using TORQUE on an android phone as display.
KermitAUS is offline   Reply With Quote
Old 05-12-2021, 03:14 AM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Hmm, power is applied to the OBD11 socket all the time.
The way around this seems to be to cut pin 16 (the +12 volt supply) and connect this to the accessory circuit. It would probably be neater to do this with an extension cable so,you avoid cutting in to the ELM327 module.
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
May 2009 Yaris sales: Down 26.9% Thirty-Nine General Yaris / Vitz Discussion 10 06-04-2009 09:33 PM
2009 Yaris Sedan vs 2009 Scion XD Jungle Rot New YARIS Purchase Forum 32 02-23-2009 05:40 PM
