Old 07-09-2015, 11:57 PM   #37
Mikastef
Drives: Yaris
Hi everyone again
Thx a lot for helping especially tdinut and Thx rigaud for taking my part.
Bronsin, your advice may be helpful and I thank you for that. However if you learned my way of thinking and my personality through all the post on this forum and even in this thread, you will learn that I'm quite investigative in nature. Check the first post on this topic. You will easily see that I have done lots lots of research. I have even listed all the potential problem that may be related to it. I have even put a microphone in my car and use a sound recorder to get the sound as raw as
possible. I have even met around four mechanic until now with no solution
You see. I'm not that stupid.
Mikastef is offline   Reply With Quote
Old 07-13-2015, 03:27 AM   #38
Girishk19
Drives: Toyota Belta
Hi Mikastef,
Me too having this problem. After 1 year. Am still in the dark. Read ur posts. Thanks guys for ur investigative work.
Girishk19 is offline   Reply With Quote
Old 07-21-2015, 08:57 AM   #39
Girishk19
Ki p dire man! moi si mo ena mm probs. check to inbox. eski nou kav rente en contact?
Old 07-28-2015, 01:13 AM   #40
Girishk19
Yes man. having the same prob for the past 2 years. have even messed up my aircon becoz of that noise. this year it became even louder. and it is stressful and tiring as i also do like 80kms per day. have tried to send u my number in inbox. seems i cant send you msgs.
Old 03-02-2016, 10:18 PM   #41
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
Bump
monchito18 is offline   Reply With Quote
Old 03-02-2016, 10:18 PM   #42
monchito18
monchito18's Avatar
Drives: Yaris sedan
Same issue here
Old 06-04-2020, 03:48 PM   #43
marianoI
Drives: hatchback yaris 06
hi to everyone
my yaris make exactly the same noise that mikastef said he had, anyone here had the same problem and could fixed?
marianoI is offline   Reply With Quote
Old 06-10-2020, 04:19 AM   #44
tdinut
Drives: 2008 Yaris Sedan Auto
For me, it was the exhaust manifold flange and gasket. My local mechanic replaced those two parts and the car went silent. I sold it several years later but still miss that car today.
Originally Posted by tdinut View Post
It's fixed !!!! My car is fixed !
Definitely all exhaust manifold related. 2 parts replaced. Flange and gasket, I believe.
I can not read the mechanic's writing. I guess the flange was making the predominant metallic sound that I was hearing. Car sounds more quiet and all seems to be perfect. I will update after a day or two to make sure nothing changes. I am so relieved and happy.
Joe
tdinut is offline   Reply With Quote
Old 06-13-2022, 04:40 AM   #45
ChloeFarwell
Drives: Good
thanks for this please like much
ChloeFarwell is offline   Reply With Quote
Old 10-27-2022, 12:22 PM   #46
almamater
Drives: Yaris 2006 - 1.0
I have the same problem on my Yaris 1.0 2006, I already changed spark plugs, etc, but we haven't found the problem. The mechanic told me now that it could be the 'anti squeak sensor' something like that, does anyone know if this exists? He even showed me in the engine where this sensor is, small connector behind the motor.
On the web I only find a camshaft sensor, is it the same thing?
almamater is offline   Reply With Quote
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
