Old 11-21-2020, 02:13 PM   #1
misterno
Drives: Toyota Yaris
Best brake pads and rotors for 2009 Yaris
What should I buy if money is not a concern. I heard ceramic brakes are the longest lasting. I am not sure about the rotors
Amazon and ebay has lots of chinese made so I am not sure where to go.
misterno is offline   Reply With Quote
Old 11-22-2020, 12:45 AM   #2
zoidberg444
zoidberg444's Avatar
I've had a few different brands in my car over the last 10 years but the best stuff I've had is the Bosch brand stuff I put in just a few weeks ago. I had some cheap "pagid" and "eicher" brand stuff Euro Car Parts here in the UK sell and honestly it was shite.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 12-04-2020, 06:09 PM   #3
SRV2NV
Drives: 2007 Yaris 5 door
I followed the advice of a bunch of car guys and tried the Wagner ThermoQuiets on my last break job and have been happy so far. Decent quality for the money and went in smoothly with no issues.
SRV2NV is offline   Reply With Quote
Old 12-04-2020, 09:01 PM   #4
CB900F2
Drives: 08 Sedan
Akebono Pads, and Fremax rotors...
Old 12-04-2020, 11:44 PM   #5
What are you looking for? Better performance (more bite, less fade, etc)? Longer lasting?
Generally speaking, the higher the "performance" the brake pad is, the more dust and noise they will have. They will also require higher temperatures to be within their operating temps, so they may actually perform worse than OEM when cold (both weather-wise and the pads themselves).
Rotors, stay away from "cross-drilled" ones. They will crack on you, especially cheaply made ones. If you need better water dispersion, you can get slotted only rotors. However, ventilated "blank" rotors will be more than enough.
Also think about your brake fluid too. That's overlooked a lot, and a lot of the times, is probably the one thing you need to change if you just want better brake pedal feel and response.
Now, if money were not an issue, probably do a 5-lug conversion (iirc, using Scion xD parts), and then get a (good, name brand) BBK.
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
New front brake pads and rotors NEexpat DIY / Maintenance / Service 7 09-10-2013 10:43 AM
08 Sedan US spec brake rotors and pads. Howardt DIY / Maintenance / Service 1 11-21-2010 05:54 PM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 10:21 AM
