Old 09-25-2016, 10:56 AM   #1
ThinkPad
Drives: Yaris XP9 1.3 '06
Rear parking sensors keep beeping when nothing is behind car
Hi,
My '06 Yaris (Europe) has 4 parkingsensors in the rear bumper. When i switch to reverse gear (stick, not automatic transmission) it will give a beep, then as the car gets closer to a wall or something, the time between beeps will get shorter, untill a solid beeeeeeep when car is reaaally close to a object.
However, since a few days ago, it sometimes constantly beeps (solid beep) even when the area behind the car is clear.
I have cleaned the sensors with a soft rag, but they weren't dirty.
Does anyone know if the car was fitted with this system from factory, or is it a aftermarket set?
What steps could i take to find/resolve the culprit of this?
ThinkPad is offline   Reply With Quote
Old 09-25-2016, 02:24 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Not sure if Yaris ever got them from factory, but they may have been dealer installed. Factory ones are easily diagnosed with a scanner as you can see what each sensor is reading. With aftermarket it may be a little tougher, but you may be able to unplug one at a time and see if the beeping stops. Note that it may disable the system completely with any one unplugged.
If that doesn't work, you will probably have to use a multimeter and compare the resistance of each sensor.
Old 09-25-2016, 02:31 PM   #3
ThinkPad
I will have a look and see if i can trae the wires, it should end up in a module somewhere in the trunk i guess.
Old 09-25-2016, 08:18 PM   #4
For the MK2 Yaris, the parking sensors were a genuine Toyota accessory, but they are not connected to the car's network for diagnostics.
Here is the Toyota troubleshooting guide for the system:
https://www.toyota-tech.eu/aimupload...hoot_guide.pdf
Old 09-25-2016, 09:07 PM   #5
bronsin
bronsin's Avatar
Im not surprised they broke.
Such is the fate of all such things....
Old 09-26-2016, 06:33 AM   #6
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
i had mine for 4 years...mines having same issue as yours...i think sh*ts getting old...😣
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Photo-Scavenger Hunt - THE LIST Black Yaris Photo-Video-Media Gallery 22 03-04-2009 08:35 PM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
Black Yaris - Photo-Scavenger Hunt Black Yaris Photo-Video-Media Gallery 2 03-01-2009 04:13 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
