Old 03-10-2023, 04:54 PM   #1
MyBlueYar
Drives: 2009 Toyota Yaris
Everything seats: sedan vs hatchback
I bought my 3 dr hatchback about one month ago, and one of the things that I knew it needed going into the purchase was a new driver's side seat. The side lumbar support (left side) has been chewed up pretty good, so perusing the lengthy posts about what options we Yaris owners have, I've come here for some timely advice.
While I could simply go to the junkyard and pick up a used seat, I stumbled across a post last night mentioning that the sedan front seats have height adjustment available. Was I sleep walking and imagining what I read?
I'm among the group of owners who find the original seats just fine, so while many of you have chosen the Rabbit, Scion xD, or other car to swap seats with, I'm simply looking for a straightforward replacement of my current seat.
Did I read the aforementioned post correctly about the sedan seats? My Yaris is the base model, and its seats only have the recline function. Height adjustment would be a nice change.
Can any of you comment about the difference in seats between the sedan and hatchback? Appreciate the feedback -
MyBlueYar is offline   Reply With Quote
Old 03-10-2023, 06:11 PM   #2
I've been around here for a very long time and can't recall anyone putting sedan seats in a hatch so there must be a reason since they are, in ways, a superior seat.
Old 03-11-2023, 02:50 AM   #3
sh0rtlife
FWIW my seat has been slowly coming apart its not ugly yet but it will be sometime this year for sure
a "good" drivers seat is not something your likely to find...HOWEVER passenger seats are dime a dozen and cherry...you can swap the skins and foam from a passenger to a driver with 2 issues...first off the sewn on carpet flap will need to be removed, and theres 1 mounting tab thats "split" that would need to be cut to match.....otherwise the seat bottoms are the same side to side....i didnt dig into the backs but i would assume the same is true assuming it doesnt have any "controls" or airbags
all of that assumes you want to maintain pattern match of the seats to the doors...if not then ANYTHING can fit if you can weld and fab....ive been eyeballing TC seats as well as XB seats
Old 03-11-2023, 05:21 PM   #4
Neinris
Drives: 08 Yaris 3 Door Hatchback
I heard the xD are almost a direct swap, might need to swap a connector though. They have a bit more bolster than the Yaris’ seats, and a bit higher. Pic below is xD seats in Yaris, not mine.
I’ve been eyeing tC seats too, didn’t look into xB’s though. Would FRS fit with minor mods? I’m more worried about the airbag weight sensor than having to making a bracket.
File Type: jpg 08753EC3-839D-430C-A027-B69C9A7378F5.jpg (120.1 KB, 173 views)
Neinris is offline   Reply With Quote
Old 03-11-2023, 08:25 PM   #5
sh0rtlife
ive yet to see a set of FRS with my own eyes to make any judgement
the XB and XD seats seem to sit on the same sliders and rises so id asume the "frame" is the same in them so if one fits they both do....i just recently saw a set of XD seats and they didnt seem to have much if any more bolster than an XB....and it sure "feels" like less than a TC...tc's have been falling out of the woodwork as of late
Old 03-13-2023, 10:27 AM   #6
Gametrader
Drives: 2000 Miata 2000 Impreza rs
The xd seats are a direct bolt in for a 2010 hatch (pic was of my car)
Had to change 1 connector under seat for the airbags (no airbag light after so assuming they still work)
A little more bolster than the stock seat but not what I would call sporty
They do sit a little higher than stock seats
Also a bit nicer quality fabric and construction
A good easy cheap replacement if your stock seats are chewed up ( like mine were)
Gametrader is offline   Reply With Quote
Old 03-13-2023, 01:09 PM   #7
Neinris
Yup... I stole your pic from our Discord channel... I had to navigate through all the topics to find it.
Old 03-13-2023, 02:50 PM   #8
sh0rtlife
this...this is what i HAVE TO AVOID....im 6'4 so a taller sitting seat is BAD
Old 03-14-2023, 12:31 PM   #9
Neinris
I'm only 5'9", long legs, short torso, I have the seat moved all the way back. I welcome the increased seat height.
Old 04-03-2023, 10:11 AM   #10
LostinSpace
Drives: 2010 Yaris
While we are on the conversation of seats, has anyone on here ever put 3rd gen (XP150) seats in their 2nd gen? Recently came across some at the junk yard and was considering
LostinSpace is offline   Reply With Quote
Old 04-04-2023, 06:03 PM   #11
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Take a look at this thread, its almost a bolt in swap
https://www.yarisworld.com/forums/sh...ad.php?t=56273
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 01-08-2024, 05:42 PM   #12
Yaruh
Drives: Yaris
That 1 connector
You had to change the yellow connector? Any photos
Yaruh is offline   Reply With Quote
Old 12-13-2024, 04:51 PM   #13
Jon11
Drives: 2011 Toyota Yaris Hatchback
I've got to ask what year scion xd seats swap into the 2010 yaris, I have a 2011 yaris and the driver seat is shitt. It's my daily and I don't want to spend $$$$ on it but i'd like to have none torn up seats. Thanks!
Jon11 is offline   Reply With Quote
1KR-FE hatchback vs 2NZ-FE Sedan tamrat General Yaris / Vitz Discussion 5 07-07-2016 01:02 AM
Sedan vs Hatchback Instrument/Gauge Cluster goku87 DIY / Maintenance / Service 3 08-27-2009 12:26 AM
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 11:28 PM
