10-19-2020, 07:53 AM | #1 |
Drives: Toyota Yaris Join Date: Jan 2015
Yaris stalling in very hot weather at low rpm
Our 2008 4sp automatic 1.5l Yaris sedan stalls intermittently or loses power at low rpm in very hot weather (>35C/100F). Car has 150k kms and has been doing it since around 80ks. Car is completely stock.
The most common set of circumstances is after car has a long period of idling or lots of stop/start driving or slowing down after a long period of highway driving. It starts again immediately with no issues. If temperature is less than 35C/100F then doesn't seem to be an issue. No engine codes have been recorded. Fuel filter in the tank has been replaced recently and resulted in no change. Throttle body has been cleaned. Spark plugs replaced. Car uses E10 fuel. To my inexperienced mind it seems like it may be a vapour lock although it does not appear to be related to amount of fuel in the tank. Any help would be much appreciated! |
10-19-2020, 07:00 PM | #2 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Try cleaning the MAF sensor. It could be very dirty injectors or weak fuel pressure.
10-19-2020, 07:18 PM | #3 |
2ZR swap. DO IT! Ask how!
Please only start one thread per issue.
10-20-2020, 10:36 AM | #4 |
Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
The Throttle body by the butterfly usually has a build up which would cause restriction when idling. Get some long cotton swabs and throttle body cleaner.
10-21-2020, 10:38 PM | #5 |
Drives: Toyota Vios Join Date: Feb 2013
i think it is quite common for Toyota old models to have low RPM (500-500rpm) at idle.
some say replace A/F (O2) sensor will resolve it, but soon after a while the problem comes back again |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
England to the Nordkapp and back in my Yaris | zoidberg444 | Photo-Video-Media Gallery | 15 | 07-27-2020 08:09 AM |
Toyota Yaris Optimal RPM for Highways | Anquietas | General Yaris / Vitz Discussion | 12 | 04-28-2017 05:59 AM |
Engine fan on when standing still and low mpg 2002 yaris | andqe | DIY / Maintenance / Service | 5 | 09-15-2012 03:32 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
