Old 12-31-2020, 12:25 PM   #1
vinny121
Drives: 2007 Yaris Sedan
Unhappy Cold start issue
Hey all,
My 165K Yaris doesn't want to start. When I turn the key, all I get is clicks, the engine doesn't make any noise. The 3yr old battery seems to be fine; it has 12.2 V. I checked OBD for codes and found none. Would anyone have any ideas on how to fix? Thanks for your help.
https://www.youtube.com/watch?v=3oRswndBVbM
vinny121 is offline   Reply With Quote
Old 12-31-2020, 01:45 PM   #2
If you haven't already done so, clean and reseat the battery terminals.
Old 12-31-2020, 06:51 PM   #3
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
12.2 volts is low. You need to load test the battery. I think it's the battery.
alanwagen is offline   Reply With Quote
Old 01-01-2021, 02:18 PM   #4
vinny121
I remove and cleaned the terminals with a steel wire brush then reseat them with dielectric grease. There was rust on the cabling and the terminal bolts but I think know the connections are now good. When I turned the key on, I noticed that the starter was turning the engine for a few secs but I didn't hear any ignition. Then the second time, I tried key on, I heard just 5 rapid clicks and the engine wont turn over. Thanks for the suggestions.
I connected jumper cables to it and then the yaris started fine. I think the issue was the rusty corroded battery terminals not allowing the alternator to charge the battery, I did a test drive and the yaris seemed to function normally. I tested with multi-meter and it has load voltage (ie headlights on) of 8.0V. I'll have to check the battery to see if the battery maintains 12.6 volts.
Old 01-04-2021, 12:48 PM   #5
01lexpl
Drives: 07 sedan
Likely battery. When running it should be 13.5V + (or something)
Fully charged, about 12.5V, so you're below that in both cases...
Clean the terminals and spray some anti-corrosion on them. It's a necessity in Canada.
It's rare to have to change terminals on modern cars... like very uncommon, unless you constantly have put in shitty batteries which leak and form green cheese on the terminals that has rotted parts of the battery terminals.
01lexpl is offline   Reply With Quote
The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. YarisVVTi2002 DIY / Maintenance / Service 2 09-16-2019 05:43 PM
no start: engine immobilizer random issues the_teach DIY / Maintenance / Service 4 04-13-2015 07:55 AM
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 06:19 PM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Yaris sedan sputters after a cold start!! CT Scott pls help if you're out there!!!! tyrone_yaris DIY / Maintenance / Service 32 12-03-2012 02:00 AM
