Old 05-22-2022, 02:44 PM   #1
ryanquad
Drives: 05 echo sedan turbo
Question Sheared clutch into two pieces?
So the input bearing went bad in my 2004 echo 5 speed. We had a 6 speed out of a Celica GTS lying in the shed, Installed that as an upgrade. about 10 minutes into test drive im shifting into 3rd on a on ramp at 6500 suddenly no gears. got it home and took it all apart and I had sheared the clutch friction material off the center of the clutch. I have never heard of this happening, should I stay with a stock clutch to reduce driveline shock or should I upgrade to a stronger clutch?
ryanquad is offline   Reply With Quote
Old 05-24-2022, 12:48 AM   #2
sh0rtlife
funny enough ive seen this as an issue on "performance" clutches more than i have on stock units, typicaly the stockers will "slip" before the rip, where as the performance units grab hard and then the fingers get weak
Tags
clutch
New clutch, car is abysmal to drive tamrat DIY / Maintenance / Service 4 03-10-2020 04:39 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
