![]() Drives: 2008 Sedan Join Date: Jul 2017
Front wheel bearing
I have a 2008 yaris without abs. I replaced a front wheel bearing 9 months ago with the beck/arnley one. It has failed 8,000 miles later. Would anyone happen to know if the abs one can be used for non-abs? The only non-abs one I see is the same one. The measurements look identical.
Yes, you can use the bearing meant for an abs equipped model.
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
get KOYO bearing rather than other
#4 | |
bearings
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
always get toyota parts if you can, they lastso much longer in my experience as a technician
Thread Tools | |
Display Modes | |
Need front wheel alignment specs | Rob888 | DIY / Maintenance / Service | 1 | 03-05-2020 03:53 PM |
Need front wheel alignment specs | Rob888 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-05-2020 03:52 PM |
Can't find front hub bearing assembly with ABS anywhere! | PrettyWreckless | DIY / Maintenance / Service | 5 | 04-09-2018 03:15 PM |
Mixing wheel sizes. front 195/60r15, back 195/65r15 (or viceversa) | badillin | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-04-2017 07:10 PM |
10mm or 15mm wheel spacers for front wheels? | b20vteg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 06-05-2014 11:08 AM |
