Old 01-10-2021, 04:12 PM   #1
paraklas
Drives: Vitz 2002 1.4
Brake Failure only when pressing the pedal gently
Hi, quite recently, wife's 2002 (94000km) Yaris developed a braking issue, which i can easily replicate.
When I sharply (i.e. for immediate stop) press the brake pedal, it bites without any sponginess or other issues and car stops properly. Bite is at around 15-20% travel.
When I slowly press the brake pedal or modulate it just a bit, it will start to go down until it bottoms. There is minimal to no brake force and car continues to roll. I noticed that, while bottomed the minimal brake force is only applied at the front/right wheel (perhaps because it's the closest to the master cylinder?)
If I release and press back immediately, it will bite normally.
- Car was fitted new brake pads/disks last year, no issues till yesterday.
- New brake fluid yesterday but made absolutely no difference
- No leaks, brake fluid was always full
- ABS works fine
Took a video, sorry for my out-of-colour socks and speaking in Greek, narration is that I slowly press the brake or modulate it a bit till it hits the floor.
https://youtu.be/AL3zt1E2HiA
paraklas is offline   Reply With Quote
Old 01-17-2021, 11:26 AM   #2
ghowey
Drives: 2010 Yaris Sedan
These are common symptoms of a failed master cylinder.
ghowey is offline   Reply With Quote
Soggy Brake Pedal 06YarisRS DIY / Maintenance / Service 3 07-14-2020 11:56 AM
Creaking noise when pressing brake pedal hard? xdarkxfirex DIY / Maintenance / Service 2 11-06-2017 09:18 PM
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 06:10 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake pedal vibrates-not rotor problem rradhay DIY / Maintenance / Service 9 11-12-2010 09:10 AM
