Old 06-29-2020, 04:55 PM   #1
maxifam
Drives: Yaris 2010 sedan
Yaris sedan tire sizes
Hello. If my Yaris takes a 185/60R 15 tire size, would I also be able to use a 195/65R15. I have some good spares
maxifam is offline   Reply With Quote
Old 06-29-2020, 07:50 PM   #2
Not really. Tire would be quite tall.
185/60 means height of sidewall is 60% of the tires 185 width. Apply same math to 195/65 and you'll understand how much bigger than stock the tire would be.
You can do it, they will physically fit. Just understand that your speedometer and odometer will no longer be accurate.
Old 06-29-2020, 10:38 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
I wouldn't install such tall rubber.
185/60/15 = 23.7" diameter
195/65/15 = 25.0" diameter
Old 07-02-2020, 03:07 PM   #4
billfires
Drives: 2010 3dr LB
I have a set of 195/65-15 tires that are on stock steel wheels that I run in the winter months. These are on a 2010 3 dr HB with a manual trans. They are noticeably taller but still are acceptable. I don't think you would want to tow a trailer or have 4 large adults in the car. The most noticeable change is in the spring when the 185/60-15 tires on aluminum rims are put back on, the performance difference is substantially better. Bill C
billfires is offline   Reply With Quote
Old 07-27-2020, 10:51 PM   #5
pica1592
Drives: 2016 Toyota Yaris LE
It's good to know that you were still able to use a set of tires of that size without much problem. I'm going to check 4wheelonline for their selections of 185/60/15 winter tires. I've been using all-weather tires, but I want to try and run a set of winter tires this year. Hopefully, I could do it with minimal adjustments.
pica1592 is offline   Reply With Quote
Old 08-01-2020, 08:44 PM   #6
billfires
Drives: 2010 3dr LB
pica, I also have a set of mounted, studded 195/60-15 snow tires that I will put on if they forecast a substantial storm. The only thing that will stop my Yaris if the snow is so deep it lifts the underbody. Bill C
Old 08-03-2020, 10:28 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
the biggest thing beyond clearance is it effectively makes your gearing taller, while also throwing your speedometer and odometer off.
do as you may with that knowledge
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Toyota ending Yaris Hatch & Sedan production for United States by end of June ferio252 Third Gen Yaris General Discussion 18 07-13-2020 01:05 PM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
