08-02-2022, 08:40 AM | #1 |
Drives: toyota yaris RS Join Date: Jun 2021
slight wheel height difference..
Yes slight wheel height difference from each wheel even when parked on a levellled ground. I have brand new shocks installed a few months ago. Im changing the jounce bumpers next week at the rear. Anyone know what this can be ?
08-02-2022, 10:52 AM | #2 |
We've been through this before. Is this different?
You need to quantify "slight". 1/8", 1/4", 1/2"? Are you raising an issue of a difference between front to back meaning you are expecting car to sit level, or side to side indicating car is leaning? Measuring from ground to top of wheel arch? Right now, this is how my own car is sitting. Measuring from ground to top of arch; LR 24 3/4" RR 25 1/4" LF 24 1/4" RF 24 1/2"
08-02-2022, 07:52 PM | #3 |
my front right is at 25 3/4
front let is at 25 1/4 rears are closer from eachother sitting at 25 7/8 this was done on an even floor..at the alignement. |
08-03-2022, 01:37 AM | #4 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
sagged springs, bent/tweaked sway bar, twisted chassis...if the measurement was taken at the arch not the rail it could be as simple as panel alignment
08-03-2022, 06:57 AM | #5 |
we rotated the springs when changing the shocks... still gave same results.
08-04-2022, 02:35 AM | #6 |
thats usefull atleast then you know its that side...question is where is the measurement comming from IE frame height arch height...i know that some alignment machines base the measurement from wheel to wheel measurements which can sckew things alot
i still stand by my original assesment..you just ruled out the springs is all |
08-04-2022, 10:34 AM | #7 |
fender arche to floor... also to note. If i park my car on opposite side of road it kinda levels out to even measurements or atleast closer.
08-05-2022, 12:14 PM | #8 |
"if" you park a car with a sway bar in the same off angle spot day after day youll settle the swaybar into an off angle position that can hold for a very long time...its not bent per say so much as tweaked and needs to be not parked in that spot ever again
08-05-2022, 06:22 PM | #9 |
bro my car sleeps inside and my garage is not levelled at all.... swaybar bushings you mean ?? If its the bushings i can get em changed...no prob.
Similar Threads | ||||
Steering Wheel Audio / Cruise Controls for Yaris RS | thelintonwyrm | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 02-04-2017 10:05 AM |
Difference between Japan and France 15" steel wheel | adrew | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 02-23-2016 12:32 AM |
Is there a ride height difference between these two OEM tires? | Frankd1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-27-2010 05:51 PM |
Driving wheel doesn't lock when taking off the key | Pingouin | General Yaris / Vitz Discussion | 5 | 09-08-2010 11:15 PM |
new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 02:37 PM |
