Old 02-04-2021, 10:32 AM   #1
Ashyaris
Drives: 2015 Yaris
2015 2D Hatch Keyless Entry Help!
I have been trying to install a keyless entry, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and followed the info I found from this forum to splice into wires 9 and 10 in the ECU harness, violet and beige. The locking works but unlocking does not. I am trying to figure out what I did wrong, I am thinking either its the box I bought or I spliced the wrong wires. Any help with this would be appreciated!
Ashyaris is offline   Reply With Quote
Old 02-04-2021, 04:32 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It could be worthwhile to check the door lock and unlock relays.
These appear to be in the Instrumemt Panel Junction Block mounted on the bottom of the Main Body ECU. I think this location is also referenced as the under instrumnet panel fuse location. My diagram shows the relays located next to the 20 Amp "DOOR R/L" fuse, but this may be wrong.
One relay is used to lock the doors, and the other unlocks the doors. You can check their operation by swapping the relays.
Old 02-04-2021, 04:58 PM   #3
Ashyaris
Drives: 2015 Yaris
Thanks for the response!
So just so Im clear your talking about the fuse box under the hood and not the fuse box under the steering wheel? Because I do not see any relays near the fuse box under near the pedals, unless they’re covered or something. Just for clarification I have attached a pic of where I spliced the wires
File Type: jpg 07BDE537-501E-4831-8760-D5A2F0B5100A.jpg (169.8 KB, 36 views)
Old 02-05-2021, 04:45 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I'm just working from the wiring diagram and drawings in the service manual.
I have attached these for you. Hopefully these will help.
Old 02-05-2021, 05:07 PM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I just went out to the garage and checked on My Yaris. It sounds like the relays are either behind the fuse panel under the dashboard, or inside the body ECU.
The unlock signal should be an earth on pin 10 of connector F82.
Tags
2015, help needed, keyless entry, wiring
DIY keyless entry Viper 211HV w/ pics tmontague DIY / Maintenance / Service 20 12-04-2023 03:46 PM
Factory keyless entry on the L model? Yes! Dodge Aries K Third Gen Yaris General Discussion 24 07-27-2020 01:04 AM
Request for DIY Keyless entry and remote start for Yaris 2015 L YarisCA Third Gen Yaris General Discussion 3 10-29-2016 10:08 PM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
