04-24-2022, 06:53 PM | #1 |
Drives: 07 Yaris Join Date: Apr 2022
2007 Yaris manual trans shifting from 2nd to 3rd not smooth
2007 yaris 5 speed with 106k miles. Shifting from 2nd to 3rd isn't smooth like all the other gears. I changed the fluid using Valvoline 75-90 conventional and I also lubed the shifter and still the same. Should I use synthetic gear lube? Does anyone else have this issue?
04-25-2022, 05:18 PM | #2 | |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
04-26-2022, 07:12 AM | #3 |
When shifting from 2nd to 3rd, there's a little resistance but there's no grinding noise.
06-07-2022, 08:37 PM | #4 |
Drives: 08 Yaris Base 3dr Join Date: May 2022
I have a similar issue, I changed my gear box oil (Royal Purple) and it felt brand new. Though I do have a leak and the problem is beginning to occur again.
06-16-2022, 06:10 PM | #5 |
How many miles did you put on the car using the Royal Purple before the problem started again?
Sometimes now I just shift from 2nd to fourth. |
06-22-2022, 08:39 PM | #6 |
Drives: 2007 Yaris Hatchback (US, MT) Join Date: Jan 2017
Mines always been a little rough/grindy going from 2 to 3 unless I make sure the my speed and rpm are fairly low (under 3000). Not sure I want to know what it would cost to fix.
07-30-2022, 09:15 AM | #7 |
Has anyone used 75W80?
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2007 Toyota Yaris Hatchback Manual - Make an Offer! Southern Ontario Canada | hodginsa | Cars for Sale by private party | 4 | 09-20-2019 07:37 PM |
Dropping the tans in a 2zr swapped Vios | tmontague | Performance Modifications | 2 | 04-29-2017 07:29 PM |
2007 Yaris: jerky part throttle and trans. freewheel | Cartel | General Yaris / Vitz Discussion | 0 | 03-04-2017 03:19 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
