Old 06-26-2021, 07:30 PM   #1
Maui Paul
Drives: Yaris hatch
fast click sound no start
08 Yaris hatch, just checked battery at 14.4V
turn the key, fast clicking but no start
Do these cars have voltage regulator that can be replaced or is it likely the starter or something else?
thanks
Maui Paul is offline   Reply With Quote
Old 08-01-2021, 01:33 AM   #2
ralley77@?!
Drives: 2008 Yaris RS
When you checked the battery did you just touch your meter to the terminals. Disconnect the battery cables and clean them with a terminal and post cleaning tool. Any auto parts store should stock one cheap. Start with that. Also check the connection from the battery to the alternator to make sure it is not corroded. Make sure to disconnect the positive battery cable before doing this. The clicking sound usually indicates the relay isn't getting sufficient power.
ralley77@?! is offline   Reply With Quote
Old 08-17-2021, 10:08 PM   #3
Titten_Maus
Drives: 2007 Yaris Hatch
I know you checked the voltage, but did you try jumping it?
Titten_Maus is offline   Reply With Quote
Old 01-27-2022, 09:42 AM   #4
IndestructibleYaris
Could be a bad starter solenoid. You won't know unless you check the voltage drop at the solenoid post, battery connection at solenoid. Try jumping the solenoid to see if that works.
Hold in coil inside solenoid could be damaged
Solenoid battery connections corroded or loose
Internal solenoid connections corroded
Battery connections corroded or loose
Starter shorted
Starter high resistance
Starter open circuit
Could be many things, best to check everything with a multimeter and get familiar with voltage drop testing
IndestructibleYaris is offline   Reply With Quote
Old 01-28-2022, 03:38 PM   #5
Maui Paul
Drives: Yaris hatch
twas the battery
It was the battery. Replaced with WalMart Everlast, perfect fit, good warranty,
and relatively cheap.
Mercedes has a very inexpensive voltage regulator made by Bosch that is relatively easy to replace, often failing at 60K miles...
The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. YarisVVTi2002 DIY / Maintenance / Service 2 09-16-2019 05:43 PM
Cranking sound on cold start / Yaris 2009 1.33 VVT-i stefantomic DIY / Maintenance / Service 2 06-19-2019 10:02 PM
Humming Sound on Transmission Uno DIY / Maintenance / Service 0 01-29-2016 06:54 AM
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 12:58 PM
Raising the sound stage... SAV912 In Car Entertainment + Electronics (audio / video / alarm) 11 07-30-2011 05:26 AM
