Old 05-21-2021, 03:59 AM   #1
ncp93
Drives: Yaris Sedan 2011
Toyota Belta (JDM Yaris) stock HID Headlight project
Hi everyone! This is my first time to post on this forum and hoping I am doing it the right way.
I am currently building a JDM inspired Yaris Sedan, and I am keeping it as JDM as possible. I have the stock HID headlights from Japan sitting on my shelf for a couple of months now. As the last time I compared them with the stock headlights, they seem to have larger diameter wires.
Was there anyone here who successfully installed one of these?
By the way, I was able to install the Tail lights from Japan before and here is the video: https://www.youtube.com/watch?v=gwxmPYc3Gb0
If you are also interested on checking the lined up parts to be installed, you can check the project introduction right here: https://www.youtube.com/watch?v=0PW9_FUdW68
Or just search "The Project Belta EP1" on YouTube.
Thank you for your interest.
I am looking forward to have a healthy discussion about the project. Thanks everyone!
ncp93 is offline   Reply With Quote
Old 05-21-2021, 05:05 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
What is the part number for the ignition key light ring?
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 05-23-2021, 06:00 AM   #3
stidnam
Drives: Starlet
I think you'll find that factory Yaris lights run something like a 10a fuse, whereas the HID lights will be 15a.
I used to have JDM HID headlights in my third gen Yaris and I ran them off the 10a fuse without blowing a fuse, but if you're at all concerned, I'd be inclined to run new relays just to be safe.
stidnam is offline   Reply With Quote
Old 05-23-2021, 10:44 PM   #4
ncp93
@mitch9521
Sorry mate, we do not know the part # as we got this from a wrecker without any documents.
@stidnam
Thanks for your input. Have you noticed any difference on the wire diameter on yours? And you also had to change the connector yea?
Old 05-24-2021, 12:11 AM   #5
stidnam
Drives: Starlet
I can't recall diameter as it's been a couple of years. I had new plugs with pigtails that I spliced into the existing wiring that went to the h4 plugs. However, I ran my earth wires directly to the chassis. So the only wires I had to worry about were the two positive switched ones going to low and hi bean.
I'd be looking at running separate relays and new wiring. You'll also likely find that the JDM headlights are positively switched as the high and low beams need to be on at the same time when hi is activated. You'll want to check how your current lights are wired.
Old 05-24-2021, 02:36 AM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
there's a JDM hatch walk through somewhere...did i start one a few years back? i forgot. had jdm headlights since 2013.
Old 05-24-2021, 02:45 AM   #7
enviri
enviri's Avatar
Drives: 2010 Yaris
https://www.yarisworld.com/forums/sh...&highlight=HID
Old 06-08-2021, 03:43 AM   #8
ncp93
Thank you so much for the inputs!
For the mean time, I decided to keep the headlights until I'll find the original harness from Japan. If I won't be able to source one, I will try to work on it with connector conversion and changing wiring diameter if found needed.
I will surely update this thread in the future once I have completed the project, for the community's reference.
Old 08-06-2021, 01:55 PM   #9
01lexpl
Drives: 07 sedan
Just cut your current connectors off and solder the new with the old?
I did this on my old Lexus... as I bought some Kouki headlights & corner lights... had to splice and dice the connectors as only one matched the USDM versions.
I kept spare wires disabled (as the new lights had AFS, but my car did not).
01lexpl is offline   Reply With Quote
Tags
belta headlight, hid headlight, jdm headlight, jdm yaris, stock hid
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
For Sale: 2007 Toyota Yaris Liftback/ Hatchback Misterawa Cars for Sale by private party 1 07-04-2015 12:38 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
