Old 07-07-2021, 11:20 AM   #1
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
High beam indicator stopped working
I noticed the other day I was driving with my high beams on, turns out the blue indicator in the dash isn't lighting up anymore. Is this simple enough to replace? What part would I need to buy?
The garage I take my car into replaced my headlight bulbs with LEDs a few months back. I had a blown bulb and they asked if I'd like to swap them out for LED, so I figured why not. I'm not sure if this would contribute to it. I'm about 95% sure the high beam indicator was working since.
teddy is offline   Reply With Quote
Old 07-07-2021, 02:06 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
As far as I know all of the indicator lights on the cluster are LED. I doubt the LED blew but you can pull the cluster out and check the circuit board on the back of it.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 08-21-2022, 07:13 PM   #3
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
Did you ever figure this out? I replaced my headlights with LED's as well and I'm experiencing the same problem.
TommyWasabi is offline   Reply With Quote
Old 08-22-2022, 08:25 AM   #4
teddy
Unfortunately no. I ultimately went back to the original non-LED bulbs. The LED lights had flicker in the DRL and were way too bright. Once I was back on the old bulbs the indicator worked again.
Old 08-22-2022, 09:36 AM   #5
TommyWasabi
I did some digging on the interwebs last night and it looks like most with this problem added a resistor in line and it fixed the problem. Apparently the LED's can cause some tricky problems. Anyway, I found a solution that essentially is a plug in. Just in case you ever want to go back to LED's in the future.
There are various ways to do this but this will work as a plug and play solution:
https://www.superbrightleds.com/moto...-load-resistor
Old 08-22-2022, 10:29 AM   #6
teddy
Huh, that looks simple enough. I wouldn't go back to LEDs - the housing isn't designed for them so at night I was blinding oncoming traffic.
I'm waiting for my Corolla Hybrid to come in, so will be saying good bye to Yaris after almost 15 years :)
Old 08-22-2022, 04:18 PM   #7
sh0rtlife
you dont even need a real resistor just 2 tiny 12v to 3v resistors paired up run from the LOW to ground on the bulb socket...its how i fixed my HID's and its been since dec with no issues
to be clear im talking aboutthe same resistors you get in a bulk pack of LED's
i belive what i used was a pair of 1ohm
Old 08-24-2022, 04:50 PM   #8
TommyWasabi
Good stuff, I know I have a few resistors some where...
Yaris Verso High beam problem henry33 DIY / Maintenance / Service 1 09-21-2016 09:31 PM
rear axle beam compatitbility? AndreS123 Third Gen Yaris General Discussion 3 08-25-2016 04:23 PM
Front wipers high speed not working properly WildChild DIY / Maintenance / Service 1 07-30-2016 01:00 PM
Dimmed high beam as DRL? Ot_tO Cosmetic Modifications (Exterior/Interior) 5 08-21-2012 12:34 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
