Old 07-13-2021, 11:38 AM   #37
Neinris
Wished this car was available in the US. I love how my 08 two door hatch looks, but this weighs 63lbs lighter. I wouldn't have to go on a diet when I decide to make mine a track car.
Old 07-13-2021, 01:26 PM   #38
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You can import them from Canada into some states, MI is really easy. Or you can import RHD versions from Japan in a few years once they get out of the 25-year blackout period (they don't have FMVSS or EPA certification for North America).
Old 07-13-2021, 04:09 PM   #39
mitch9521
Manual elitist
mitch9521's Avatar
Drives: 2014 LE, 2007 F150
I love this build so much.
2014 Yaris LE 5 Speed - Netz emblem, fog lights, TRD sway bar, Blitz ram air, JDM tails, TRD short shifter, 15-17 radio, SE/RS spoiler, weeb stickers, projector retrofit, SE cluster, NST crank pulley, MR lowering springs, SE rear bumper - Daily driver
2007 F150 STX 4.2L 5 Speed - towing mirrors, Back Rack, weeb stickers, chrome bumpers, Lariat grille, Mark LT headlights - Pampered workhorse
Old 07-14-2021, 10:17 AM   #40
Neinris
Sorry in advance for hijacking the topic... I've always loved the Vitz, even when I used to play Grand Tourismo on the PlayStation, I didn't care that my friends would laugh at me.
Yeah but it'd be in KPH... LOL! Not really a deal break. RHD is a no go for me, it'd be hard to drive on the CORRECT side of the road.
Not sure how much I'd have to pay through customs if I get one from Canada, any idea?
But back to the build... Kudos to the OP, your work inspires lots of us. Please post new dyno test after everything is completed.
Old 07-14-2021, 12:46 PM   #41
CrankyOldMan
For Michigan, you just transfer the title at the Secretary of State and pay whatever applicable taxes/fees for the value of the vehicle. Not sure about customs though since I bought it from TheBarber (who is a Canadian National that lives in MI on a visa). Check with your state's rules for importing vehicles for more details, I guess. :)
Old 07-15-2021, 10:50 AM   #42
Neinris
I really want to get back to the build, sorry for hijacking again. But thank you for that information. I'm still on the fence about it. I'll be moving back to Maryland sometime next month. Maybe I'll start inquiring when I get back.
I might just stick with my 08 Yaris, and start my own project. Thanks to the OP, some others here, and others on YT who have inspired me with their Frankenstein engines that I want to start my own Frankenstein project. I've vaguely mentioned in own "Frankenstein" post (https://www.yarisworld.com/forums/sh...ad.php?t=63299) about maybe putting a 3ZR bottom end for stroked crank, 2ZR-FXE 13:1 compression pistons, and 2ZR-FE head (no valvematic) together, the kicker is 2ZZ intake runners! Now that's a Frankenstein.
I'd take years for me to put that together. So anyone is more than welcome to experiment and steal this idea.
I'll end my question so we can focus on the OP's build.
Old 07-15-2021, 10:57 AM   #43
Neinris
What is the REV limit for this engine? Is it purely going to be a track car, or is it still going to be a daily driver? Any plans on changing the gear ratio of the transmission? Very few here in YW have changed to the Scion xB1's (bB in most part of the world) transmission, for a higher final drive which would put more torque to the ground, but loses on top end speed. I personally would go with the Scion xD's manual transmission and just change out the 5th gear for better fuel economy, the FD is between the Yaris and the xB1.
Old 07-16-2021, 10:00 AM   #44
CrankyOldMan
The Echo uses the C15X gearbox family, not the C5X. That really limits the availability of options without going back to much older cars (80's/90's) to find compatible gears. That rules out the xA/xB/xD and all of the 1ZZ-based platforms.
That said, the shorter final drive is great for AutoX but awful for road courses. Way too much top end speed given up, even with the 0.725:1 super-overdrive from the C59.
Old 07-16-2021, 08:21 PM   #45
speedworxs
Drives: |Mr2
The c-gearbox will work for both engines (the c56 is paired with the 1nz vitz rs in Japan)... Just the need correct bellhousing section. But, I thought the echo chassis was narrower in the front and that's why it used the c150box, as it was physically smaller to fit. Likely the xB gearbox or xa would be the best bet for gearing differences, as the echo was mainly for fuel economy not any real performance
speedworxs is offline   Reply With Quote
Old 07-17-2021, 08:39 AM   #46
RomanDave
Drives: 2NZ ITB NCP10
Are you asking about my motor?
If so:
-No rev limiter currently. Until I've got some stronger rods I'll likely set the rev limiter somewhere around 8200-8300rpm.
And yes in this case, swapping to the C56 gearbox is an absolutely magical upgrade. Having the 4.3 final drive instead of the 3.5 makes the whole thing so much better. I'd not be suprised if my 1300cc motor would have been into the 15 second quarter mile range with the C56 box.
The individual ratios of the C56 are most excellent. On the shift from 2nd to 3rd, shifting at ~8800rpm it drops down to only around 6500rpm on gear change.
So it stays in the powerband awesomely.
As for the purpose of this car, it's not a daily driver anymore as I've got a work car. But it still returns fairly decent milage, the high compression actually makes it decently economical.
I've been getting somewhere around 5.5-6 litres per 100km. So thats somewhere around 40mpg.
I could still get it a little better with optimizing the ignition timing further, will get there eventually.
RomanDave is offline   Reply With Quote
Old 07-17-2021, 04:16 PM   #47
mitch9521
Manual elitist
mitch9521's Avatar
I would love to swap my C50 for a C56, but getting one to Canada from Japan out of an NCP131 Vitz is north of 2 grand, the transmission itself is usually under $600 CAD, its the outrageous shipping that gets expensive very quickly.
Old 07-17-2021, 11:47 PM   #48
RomanDave
Meanwhile in New Zealand an RS model NCP91 had its C56 sit there at a DIY wrecker yard until the car got crushed... because I procrastinated too long to get it out!
One thing I noticed is that the shifter linkage arrangement and the engine mount positions are different on the later boxes (compared to my model)
The benefit is that it gives much much much better clearance for the exhaust and shifter cables.
A turbo swap would be a tight squeeze with an NCP13 box, if I was trying it with a half decent sized turbo I'd probably try make the NCP91 box work.
Old 07-20-2021, 11:11 AM   #49
Neinris
If so:
Attachment 61804
That is awesome information! Do you get the Scion xD equivalent in New Zealand? It has a final gear drive of around 3.94, might be something to look into. The xB1, xD, and Yaris all have the same 1st to 5th gear ratio, just different final gear ratio, 4.31, 3.94, respectively and the Yaris here have 3.72, not 3.5 like you mentioned.
I wish I know how to tune the ECM, because I have another "Frankenstein" in mind.
Old 07-21-2021, 02:27 AM   #50
mitch9521
Manual elitist
mitch9521's Avatar
The 1st gen Yaris was labeled as the Echo in Australia, New Zealand and Canada. They have the 6 bolt C150 transmission with the god-awful 3.52 ratio.
The 2nd and 3rd gen Yaris have the slightly better ratio'd C50 with the 3.72FD. I wouldn't even waste my time with swapping in a better FD into a C50 gearset. They're still very much an economy transmission.
Old 07-21-2021, 10:56 AM   #51
Neinris
I'd have to disagree, remcafee mentioned that he swapped in the xB1 FD and made the car really lively. I personally would go with the xD FD, which is easy because the transmission is already mated to the engine that I want to swap in.
prius c 1nz swap Zedicus Performance Modifications 23 03-27-2021 01:21 PM
Prius Piston swap in 1NZ (update pls) rabbito Performance Modifications 2 06-12-2016 10:18 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
