Old 11-27-2021, 07:43 PM   #1
menso002
Drives: 2012 Yaris
rpf1s 15x7 35+
Hey guys i just got some rpf1s in the size mentioned above, i wanted to know how these can be fitted on and what modifications will need to be done, everything is stock in the car and im guessing i will need to remove fender liners and roll the fenders. Does anybody know if spacers will be necessary as well? Ive seen other posts of other people fitting 15x7 35+ with seemingly no problem but ive also seen some that do have problems as well, id assume that would be because of wheel design but i wouldnt really know, im just a noob and dont know much about cars. Any help is appreciated, thx. Also forgot to mention my tire setup is 195/50/15
menso002 is offline   Reply With Quote
Old 11-28-2021, 10:35 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Put them on, see if they rub? You're not on lowering springs so wheel arch clearance shouldn't be a serious issue.
You can also look at online tire size comparison tools to check for suspension and fender clearance. The old one at rimsntires.com seems to be gone but there are others to be found.
Old 11-28-2021, 04:59 PM   #3
Jason@SportsCar
Should be fine with that size tire.
I use the same wheel with a 1/4" spacer, and a 215-580-15 tire with a fender roll and camber.
Old 11-29-2021, 01:01 PM   #4
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
They fit right on, no need to do anything except fitting spigot rings.
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 11-30-2021, 10:09 PM   #5
remcafee
they should fit with room to dpare for lowering springs, i have 16x7 35 offset enkeis and lowered on tein springs and still no rubbing
Old 01-03-2022, 10:06 PM   #6
menso002
Drives: 2012 Yaris
yeah it really wasnt a issue, they fit right on. i was worried because sites like ebay and amazon said they did not fit and there wasnt much i could find to really prove that or not.
Old 01-04-2022, 05:09 AM   #7
menso002
Drives: 2012 Yaris
thank you guys for the help, i wished i would of known the 16x7 fits before i bought these i would of totally gone for it! i was also hoping they would of changed the feel of the car more than they did. :/ This is my first time buying wheels so i didnt really know what to expect goung from the stock steelies to these. it only cutting around 6-7 pounds but i still thought it would of been more of a change in ride quality, i guess its just my inexperience . Still thanks for all the advice, i aprreciate it. cheers
Old 01-21-2022, 08:57 PM   #8
sh0rtlife
ride quality is more noteable in tire sidewall and tire construction, i run 15inch steelies for winter and 14s for summer the 15s are TALL and rub slightly on full lock...no real ride change, i suspect once you get to 16+ is where the real change is at
FS: SoCal 15x7 +41 RPF1s w/ Tires Dabuu Items for Sale by private party 5 01-30-2017 10:01 PM
FS. 15x7 RPF1's 35 Offset andres3165 Items for Sale by private party 5 08-10-2014 10:22 AM
Enkei Racing RPF1's 15x7 2manywheels Wheels, Tires and Suspension Forum sponsored by The Tire Rack 34 02-22-2012 05:34 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
