05-11-2017, 10:55 PM | #1 |
Drives: 2007 Yaris manual dark silver Join Date: May 2006
07 yaris wont start
Went to start my yaris yesterday and it wouldnt start no click nothing. Radio comes on all lights work. Battery is charged even tried using a new battery. Took the starter to oreillys and have it bench tested. Oreillys said its good. I'm going to take it to another place to have it tested tomorrow. We pop started it today and it drove fine. 07 5 speed.
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
05-12-2017, 04:20 AM | #2 |
Just a Gaijin
Check out this thread: http://www.yarisworld.com/forums/showthread.php?t=58254
There is a lot of useful Information |
05-12-2017, 05:37 AM | #3 |
Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
sounds like you should check the neutral safety switch
05-12-2017, 08:53 AM | #4 |
Hiw can i test the neutral saftey switch.
05-12-2017, 08:58 AM | #5 |
its under the clutch pedal at the firewall
05-12-2017, 09:46 AM | #6 |
I know where it is. How do i test if its bad?
05-12-2017, 07:44 PM | #7 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Get a test light, hook the end up to ground & see if you have voltage on both sides of the switch as you push on the clutch pedal.
05-13-2017, 08:44 AM | #8 |
You can push the switch with your finger as you turn the key to the start position to test it also. Just make sure you're in neutral. Sometimes floor mats get in the way an don't let the clutch push down far enough. That happens on my Mother's Matrix XRS sometimes.
Unplug the switch and jump it with a paperclip if the switch is bad. |
05-15-2017, 10:51 PM | #9 |
Not the neutral switch. Changed thw starter whats next. Remeber i can get it running by pop starting it.
05-15-2017, 11:39 PM | #10 |
Why did you change the starter? Wasting money isn't going to solve the issue.
Test all the systems that have to do with the starting circuit before you go wasting money on a guess. |
05-16-2017, 08:47 AM | #11 |
Drives: White '07 3dr LB Join Date: Jun 2016
05-16-2017, 08:30 PM | #12 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
wait!!! if you can pop start it, then you have a standard transaxle. NSS is on an automatic transaxle. you do not have a NSS. you can get the starter tested before replacement.
did you test the resistance in the clutch switch? did you check the resistance in the start position on the ignition switch? did you test your battery? |
05-21-2017, 11:10 PM | #13 |
David called it. Two fuses out. I dont understand how they went out but its fixed now. Fyi new starter was returned. I work in a shp with easy access to parts.
05-22-2017, 12:10 PM | #14 |
Lucky guess from an electrician ;)
04-06-2020, 04:29 PM | #15 |
Drives: 2007 yaris HB Join Date: Mar 2016
01-11-2022, 09:16 PM | #16 |
Drives: 2007 Hatchback Auto Join Date: Jan 2022
Similar issue here
01-11-2022, 09:17 PM | #17 |
Starter relay?
I am thinking I have a similar issue, am going to test the relays just get overwhelmed by electrical diagnostics. Youtube has some good videos am watching.
01-22-2022, 02:08 AM | #18 |
Turns out it was my shift lever not going all the way into position.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Hard start in the morning 2008 Yaris CE | volks_r_us | DIY / Maintenance / Service | 9 | 03-09-2018 03:18 PM |
Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 08:08 PM |
2007 yaris instrument cluster dead and engine won't start | dchippowski | DIY / Maintenance / Service | 2 | 05-17-2015 11:00 AM |
2008 Toyota Yaris Hatchback Wouldn't Start | kieranhiggins | DIY / Maintenance / Service | 2 | 05-12-2015 08:18 PM |
