09-12-2011, 03:55 PM | #1 |
Drives: Yaris Hatch Join Date: Sep 2007
Coolant Flush
Hey All,
I'm wanting to do a coolant flush on my 07 yaris LB (just under 110 k but would rather do it now vs the winter). I've done a bit of searching and would love some clarification if at all possible. From what I gather there are a couple different places under the hood that need to be drained: 1. The radiator (drain at bottom) 2. The overflow tank 3. The block via the valve on the backside of the engine I still haven't looked for number 3 yet does anyone have an idea where exactly this is? yaris-me also posted this "You don't have to drain the block. Warm the engine, then open the drain plug on the bottom of the radiator. When the flow slows, close drain and with the engine running, fill the radiator with water. Run the engine till it warms up and drain the water. Repeat two more times then let as much water drain out. Use undiluted antifreeze and add half of cooling liquid capacity. Run engine and fill with water till full." this sounds quite easy would I get a complete flush with this? Any extra info would be greatly appreciated! Cheers, B |
09-13-2011, 06:17 AM | #2 |
The one on the block is at the backside about half way up or down. Looks like a spigot. To access you will have to lift the car. While folks have done this various different ways I was reluctant to introduce anything but the "pink stuff" in mine. Hose water is not on my list of suitable fluids for the cooling system. Even draining all those listed you will not get all the fluid. There will be a pocket retained in the area behind the water pump and thermostat. I found this out after draining to replace my waterpump.
09-14-2011, 07:12 PM | #3 |
Drives: 2008 toyota yaris Join Date: Mar 2011
drain and flush good enough
08 toyota yaris with some big tires lol 02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile |
09-15-2011, 11:11 AM | #4 |
Drives: 2008 5 Speed Sedan Join Date: Jan 2011
I asked Toyota about changing the fluid for me and they said that Toyota Canada rec amends only drain and fill, not to flush it with any kind of pressure. i'm just going to drain mine from the rad, reservoir and I doubt i'll go for the block
09-15-2011, 11:15 AM | #5 |
That's cool. Remember to take your reading to ensure you have the protection for your area. I know it gets cold in Canada.
Similar Threads | ||||
Coolant Service | N9QGS | DIY / Maintenance / Service | 31 | 11-27-2012 06:55 AM |
Alternatives to Toyota "pink" super long life coolant | Camberix | DIY / Maintenance / Service | 10 | 03-30-2011 11:42 AM |
coolant reservoir? | toad | DIY / Maintenance / Service | 10 | 11-02-2010 11:02 AM |
coolant flush/ water pump | jstantherprsn | DIY / Maintenance / Service | 26 | 10-26-2010 10:36 AM |
Check your coolant bottle | UTVitz | DIY / Maintenance / Service | 13 | 12-16-2009 09:13 PM |
