Old 02-24-2021, 07:00 PM   #1
Mdkline
Yaris owner since 2013
Drives: 2012 Yaris LE
Battery restraints
Hello!
New here, but not to driving my Yaris. At 115k miles I am installing the car's 3rd battery. I have seen lots of posts on corrosion on the terminals, but I am experiencing an issue with corosion of a different kind: rust. The nuts on the battery hold downs just won't come off (pb break blaster nor heat helped). I cut off the J bolt on the front, but once I got the battery out of the way I say that the back doesn't mount in the same way.
I rather not have to buy a new carrier tray (toy p/n 74410-0D210). Has anyone else run into this? Any suggestions?
Thanks!
Mdkline is offline   Reply With Quote
Old 02-25-2021, 07:34 AM   #2
ex-x-fire
Get a can of fluid film. Its safe to use on battery terminals & the hold downs. Get a used carrier from a junk yard.
Old 02-25-2021, 03:24 PM   #3
remcafee
the battery tray youre talking about? or the hold down bracket where the j bolt going through?
Old 02-25-2021, 11:06 PM   #4
Mdkline
Thanks for the replies. I found myself with some free time and good weather today.
The carrier (tray) was easier to repair than I expected. Removal requires prying off all the plastic wire clips and 4-5 bolts. The threaded stud for the rear battery hold down point was only held in with two plug welds. I ended up grinding them out and welding in a piece of all thread. A coat of spray paint later and its good as new. I used the same material to make a new J bolt for the front (because I am cheap). Saved $70-80 over a junk yard, but it was still the longest I ever took to swap a battery. ��
battery light on cold start up 400 dollar yaris DIY / Maintenance / Service 17 02-22-2020 04:21 PM
Battery Relocation DIY tmontague Performance Modifications 7 03-23-2019 08:11 PM
We Have the Beats! ern-diz Photo-Video-Media Gallery 41 05-15-2018 05:58 AM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 04:43 PM
