Old 08-12-2022, 03:00 PM   #1
moozart
Drives: Yaris 1.3 2010
Break fluid change anything required for clutch?
Dear all,
Break fluid is due, I'm going to replace it. I believe the same reservoir is used for the clutch. Is there any additional step in order to also replace the fluid from the clutch? I have a vacuum pump, can I do the same as with the breaks?
Yaris 2010 1.3
moozart is offline   Reply With Quote
Old 08-13-2022, 09:54 AM   #2
ex-x-fire
Maybe gravity bleed the clutch master cylinder.
Old 08-15-2022, 12:26 PM   #3
bronsin
bronsin's Avatar
Bleed the clutch slave exactly as you would the brakes. There is no need to pull a vacuum but if you want to be my guest.
If you think about it your clutch is used 10 times more than the brakes. Every year it should be bled. If the transmission is not shifting properly and you haven’t bled the clutchs in 10 years DO THAT FIRST
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
AT fluid change interval? Yaris_Fan DIY / Maintenance / Service 11 06-03-2007 11:57 PM
2007 LB Yaris - AT - Fluid Change Interval Pavel Olavich DIY / Maintenance / Service 9 03-21-2007 06:09 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
soo whos gonna change their tranny fluid twixt DIY / Maintenance / Service 0 08-04-2006 03:09 AM
