Old 06-26-2021, 07:30 PM   #1
Maui Paul
Drives: Yaris hatch
fast click sound no start
08 Yaris hatch, just checked battery at 14.4V
turn the key, fast clicking but no start
Do these cars have voltage regulator that can be replaced or is it likely the starter or something else?
thanks
Maui Paul is offline   Reply With Quote
Old 08-01-2021, 01:33 AM   #2
ralley77@?!
Drives: 2008 Yaris RS
When you checked the battery did you just touch your meter to the terminals. Disconnect the battery cables and clean them with a terminal and post cleaning tool. Any auto parts store should stock one cheap. Start with that. Also check the connection from the battery to the alternator to make sure it is not corroded. Make sure to disconnect the positive battery cable before doing this. The clicking sound usually indicates the relay isn't getting sufficient power.
ralley77@?! is offline   Reply With Quote
Old 08-17-2021, 10:08 PM   #3
Titten_Maus
Drives: 2007 Yaris Hatch
I know you checked the voltage, but did you try jumping it?
Titten_Maus is offline   Reply With Quote
The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. YarisVVTi2002 DIY / Maintenance / Service 2 09-16-2019 05:43 PM
Cranking sound on cold start / Yaris 2009 1.33 VVT-i stefantomic DIY / Maintenance / Service 2 06-19-2019 10:02 PM
Humming Sound on Transmission Uno DIY / Maintenance / Service 0 01-29-2016 06:54 AM
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 12:58 PM
Raising the sound stage... SAV912 In Car Entertainment + Electronics (audio / video / alarm) 11 07-30-2011 05:26 AM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
