Old 08-01-2021, 09:48 PM   #1
Myles
Drives: 07 Yaris hatchback
rear end howl. sounds like a bad bearing, but it isn't
I'm trying to diagnose an issue that I have been dealing with for a while now. I drive an 07 Yaris which emits a loud howling noise from the left rear tire. This noise becomes noticeable around 40 mph, and gets louder as the vehicle speed increases. When I turn the wheel to the right, the noise will go away, but when I turn it to the left it becomes worse. I suspected the bearings were bad, so I put new ones in, but that did not lead to any improvements. I replaced the tires, coil springs and shocks, but still no luck. I'm now suspecting an alignment issue, but I have read that these cars can only be adjusted with shims. I have the printout from my most recent alignment which was done when the noise was still a problem. The left rear lists -1 camber and .11 toe. the right is -.8 camber and .2 for the toe. does this seem far enough out of spec that it would cause this type of problem? I'm at a loss. any help would be appreciated.
Myles is offline   Reply With Quote
Old 08-02-2021, 10:02 AM   #2
bronsin
bronsin's Avatar
How are the front tires and the bearings in the front of the car? The fact that it makes noise when you turn the wheels Might indicate that
Good luck and tell us what happens!
alignment, noise, rear end, tire
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
Creaking sound from the rear end after stops bumps, turns after it rained YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 03-06-2009 12:57 PM
Groaning, creaking, from the rear end after taking off from stop and sometimes turnin YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-05-2008 11:31 PM
Noise coming from rear end! tfman716 General Yaris / Vitz Discussion 15 10-28-2008 12:37 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
