![]() Drives: 2008 Yaris automatic Join Date: Jan 2023
2008 auto transmission drain plug.
Does anyone know what the metric thread callout numbers are on the automatic transmission drain plug for the 08 Yaris? I was thinking of changing it with a magnetic drain plug but I can't find this info online anywhere.
Thanks! |
I wouldn’t worry about that. Just drop the pan, change the filter,. You should measure the oil that drains out, and replace it with exactly the same volume of the new fluid.
![]() ![]() ![]() ![]() Drives: 2007 5dr canadian import Join Date: Dec 2016
in reality a mag plug isnt all that beneficial in an auto....the filter gobbles up just about everything and anything metallic wont go thru the filter anyway
![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Buy a couple of those strong magnets from Harbor Freight and stick them on the outside of the pan.
Good idea except I think the oil pan is too round. I don’t think there’s any place flat. I have use those magnets and they are really amazing!
Actually I would have to believe the drain plug is magnetic that’s already in there.
The ATF pan on my 2010 already has two magnets in it. I imagine it is the same for the 08. Also the filter is more like a screen. I replaced my filter at the time, but i won't waste my money on that again.
No need for additional magnets. There are already 2 in the pan.
If you want to enjoy your car, stay off of the internet. |
#9 | |
Is it really necessary? Probably not. Have I ever done it? No! Now manual transmission oil I change that every 30,000 miles. Usually just like two or 3 quarts of that stuff. Automatic transmission oil there’s usually something like 8 quarts.
You pretty much answered your own question Bronsin. I don't get a charge out of doing repairs on my car. Plus a new OEM filter on Amazon is $64. I'll just keep doing a double drain and refills every 35,000 Miles. I'm at 215,000 and the thing runs great.
For what it's worth, I did not change the ATF the first time until around 140,000 miles when I noticed some rough shifting during acceleration on the freeway. Changing the fluid and filter took care of that.....Amazing. |
BTW, the drain plug is not magnetic
Thread Tools | |
Display Modes | |
About to replace the transmission fluid on an automatic 2008 yaris with 172kms | jessesYaris | General Yaris / Vitz Discussion | 6 | 09-23-2021 05:51 PM |
Yaris 2007 sedan (auto) Transmission fluid change and rear wheel noise | DevilzMafia | DIY / Maintenance / Service | 8 | 12-24-2012 09:05 AM |
Auto Transmission removal | artichap | DIY / Maintenance / Service | 14 | 10-23-2012 11:27 PM |
automatic trans drain plug | eddy | DIY / Maintenance / Service | 3 | 02-15-2011 12:59 AM |
my 2008 yaris needs a new transmission | kcanuck | General Yaris / Vitz Discussion | 4 | 05-18-2010 12:27 AM |
