Old 07-09-2020, 10:44 PM   #1
TYetti
Taco Supreme
Drives: 06 Yaris RS Hatch
Hella sharptones
Hey guys first post here, I've had an 06 Yaris rs since November, and the horn stopped working recently, I always thought it was pathetic compared to my Tacoma which isn't great either, anyways I had ordered a set of shaprtones for the Tacoma, but since the Yaris horn is no good(checked relay, and fuse hooked horn directly to power and nothing) I wanna use the sharps since I've been run into the shoulder about 10 times in the last two weeks alone. Has anyone run these? I've seen some old supertone writeups, but just wanted to see some setups
TYetti is offline   Reply With Quote
Old 07-10-2020, 12:36 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Can't tell you much about horns, but welcome to yarisworld. Is your RS a 3-door or 5-door? I'm sure someone will answer your query.
Old 07-10-2020, 09:11 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Make sure you've got a solid ground connection. The horn uses the radiator supports as the path back to the battery and any corrosion between the sheet metal parts will mess with that. If you have a multimeter, check for voltage between the ground terminal on the battery and the positive side of the horn.
Old 07-11-2020, 10:47 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
I had a pair of Sharptones on my old '99 Tercel, bloody hell they were loud. Not sure I want to put them on the Yaris yet.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Hella micro de install nortonfb DIY / Maintenance / Service 3 03-24-2014 09:36 AM
Seeking Hella Tailight Slacky Willing to Buy by private party 0 09-16-2013 11:10 PM
Another Hella Supertones Install jpmck03 Performance Modifications 2 05-27-2013 06:45 PM
Hella taillights installed Brian Cosmetic Modifications (Exterior/Interior) 20 09-18-2011 11:41 AM
Hella LED Combination Rear Lamp for Yaris Sedan!!! blackgenius007 Cosmetic Modifications (Exterior/Interior) 17 01-04-2010 11:51 PM
