Old 10-22-2021, 07:01 AM   #1
rakaaw
Drives: Toyota Yaris
Wiring to new tow bar
Hello,
I am new to this forum and this is my first post so not completely sure this is the
right place for the topic. Anyway here goes.
I have a UK Yaris 1300cc built 2013 which has can bus wiring.
I am in the process of fitting a tow bar with the intention of towing a small trailer and dingy. Fitting the actual tow bar is straightforward but despite lots of research and removing panels, seats etc I have been unable to find any suitable
place to link in the wiring from the tow bar 7 pin plug.
Is there anybody around who can point me in the right?
Thanks for reading this.
rakaaw is offline   Reply With Quote
Old 10-22-2021, 12:51 PM   #2
thetut
Drives: 2007 4dr sedan
This is not exactly what you are looking for but it has enough information for you to figure out the answers. It's all I could find.
https://www.youtube.com/watch?v=f4icvF_G3ts
thetut is offline   Reply With Quote
Old 10-23-2021, 06:30 AM   #3
rakaaw
Tow bar
Thank you so much for the link.
This is exactly what I was searching for but didn’t think to search internationally.
Thanks again and very best wishes.
Gregg
Old 10-23-2021, 05:44 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I had my tow bar and wiring professionally installed. The wiring includes a module that taps power from a switched fuse in the under dash fuse panel to repeat the lights to the trailer. I presume this is to avoid changing the load on the blinkers, possibly altering the flash rate. It also means I need to turn the ignition on to check the trailer lights.
Old 10-24-2021, 06:53 PM   #5
thetut
Gregg
Glad I was of some help. I'm appreciative of your response as that doesn't happen very often in my experience which has made me reluctant to stick my 2cs in sometimes.
2010 HB tow bar for push bikes amanda_84 Australia 0 05-10-2011 12:01 AM
Tow bar for Yaris dekers General Yaris / Vitz Discussion 8 10-28-2009 05:28 AM
Tow Bar for Yaris. pismo61 General Yaris / Vitz Discussion 19 08-26-2009 12:02 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
