Old 09-28-2021, 03:53 AM   #1
Hendrix
Drives: Yaris MY2010 1.33l SOL 5d
Question Clutch suddenly not disengaging after high revs
Hi everyone,
New to the forum and trying to utilize your combines knowledge of our beloved (or hated, depending on your experiences) Yaris.
Basic info: 1.33 VVT-i, 100 Hp, [SCP9_, NSP9_, KSP9_, NCP9_, ZSP9_], MY: 2010, motor code: 1NR-FE
Manual 6 speed gearbox, start-stop.
To the point: My Clutch suddenly stopped working (no longer disengages) after driving away from the traffic light.
I was driving away fast (pushed off the road almost by a dodge RAM that wanted to cut me off... david vs goliath ) and I let it go almost into the rev limiter in 2nd gear and then suddenly the clutch did not disengage anymore and have been driving the rest of the way home without a clutch.
My biggest problem now is finding the point of failure, I have bled the clutch until it seemed empty (pedal was totally lose) and then reverse filled it up again. (from the bleeding valve pushing the brake oil in with an oil can). Did not help. The pedal feels normal again but the clutch is still not disengaging.
I did not find any drops of fluid under the car either so seemingly no leak.
Sadly I do have a CSC (concentric slave cylinder) that is located inside the clutch bell. (so if it leaks, it probably will leak in there...)
So no easy checking or replacing of the slave cylinder.
Having everything replaced will be about 2500 = 3000$ which is basically half of the value of the car right now.
So I will have to do it myself hence about 1800$ is labor costs, but being a single dad with 4 small kids.... having time (and money) is a luxury.
And before I start taking the whole transmission out to reach the clutch and the slave cylinder:
Can anyone point me in the direction of the most likely point of failure and how to check this (hopefully easily)
You will have my eternal gratitude.
Hendrix
Hendrix is offline   Reply With Quote
Old 09-28-2021, 08:06 AM   #2
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
So does the pedal still go down to the floor even though it won't disengage or does it have resistance?
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 09-29-2021, 02:28 AM   #3
Hendrix
Yeah, it feels like it works normal.. although I do not feel a certain point of where it should disengage, there is no difference in resistance when pushing down (after the initial free play of about 1/2 inch)
After bleeding it almost empty until it did not push anything out anymore, the pedal was very lose and easy to push down, I refilled it from the bottom (bleeding valve / nipple) to prevent air bubbles.
Pedal works now normal but clutch does not disengage (like before the bleeding / changing the fluid)
No drops under the car, no liquid from the reservoir disappearing...
Tags
no clutch
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 88 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
engine revs when clutch depressed Yaris#2 General Yaris / Vitz Discussion 7 02-20-2010 10:28 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
