Old 05-23-2020, 02:50 AM   #1
Thedidat
Drives: YARIS
Replaced Rim
I recently had to replace one wheel due to bent rim. I forgot about the tire pressure sensor. I’m not that familiar with how that works. My question is how do I go about fixing this so that i can once again rely on the warning system?
For obvious reasons the tire pressure warning light is on.
Thedidat is offline   Reply With Quote
Old 05-23-2020, 06:33 AM   #2
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
The sensors are the valve stem. You should of used the same valve stem and then it will be ok. Otherwise you will need to buy a new sensor and have a tire shop pair it to your system.
alanwagen is offline   Reply With Quote
Tags
Is getting the rim repaired worth it? nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 10-10-2014 04:22 AM
Rim 13" or 14" Yaris Hatchback 2008 Bearmantle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2013 12:11 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
I NEED A 15" STEEL RIM AND OEM TIRE robkay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-18-2009 10:57 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
