03-30-2012, 08:32 PM | #1 |
Drives: '08 LB MT Bayou Join Date: Oct 2008
It's Grillin' Time
Got some goodies from MicroImage today... (well I had the grill for a little while and just got it installed)
And a little something extra... |
03-30-2012, 09:33 PM | #2 |
Looks nice!
03-30-2012, 09:36 PM | #3 |
Form>Function
Two very clean mods. I always wanted that Simota so bad sucks it doesnt fit sedans.
03-30-2012, 10:00 PM | #4 |
Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
I have the same intake waiting to be installed
what do you think of it? did you have a CAI before? Cheers Will |
03-31-2012, 11:18 PM | #5 | |
It adds a nice little growl to the engine too. It's a very tight fit front to back. I had to push the battery back a bit which was somewhat problematic because I'm using a red top and its tray adapter. But it went in very quickly, was like a 15 minute job. |
04-01-2012, 12:31 AM | #6 |
Give Me Resonance
Difficulty of installing the grill? Ill be getting mine soon and would like to know the best way to do it.
(3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
04-01-2012, 02:31 AM | #7 | |
Start by lining up the part that curves beneath the Toyota logo. Set it so that it looks right then drill through the grill mounting hole at that location and into the bumper. Fasten with a zip-tie. Then do the bottom curve the same way. Last you'll need to do at least the upper two corners. I did those and the other two on the top of the grill. Depending on the size of the drill you use you may find it hard to get a good angle for drilling. Make sure you keep checking to see that it looks right. I made the mistake of pre-drilling the holes in the center of the tabs that held the old grill on. I figured it wouldn't matter if the holes didn't line up perfectly since I was using zip ties. That method didn't work well at all. So I ended up using the grills mounting holes as guides, and when drilled, the holes were usually no where near where you would have thought they should be. |
04-01-2012, 04:38 AM | #8 |
Drives: 07 YR Yaris 5dr Hatch Join Date: May 2011
Ive looking at a grill like that for ages, does anyone know if Microimage posts overseas?
And is this grill for an 07 hatch? |
04-01-2012, 11:03 AM | #9 | |
Similar Threads | ||||
05 Echo changing time on clock | jambo101 | DIY / Maintenance / Service | 3 | 11-12-2011 04:34 AM |
Joke Time | ubospawis | Middle East | 22 | 09-30-2010 11:29 AM |
Yaris at Summit Point Time Trials | Redbat01 | Tracking, Racing, Auto-X Forum | 1 | 05-06-2010 12:30 PM |
Time Attack Invades Houston! | Rollmodl | Southwest | 8 | 05-03-2010 08:00 PM |
