Old 06-29-2020, 04:55 PM   #1
maxifam
Drives: Yaris 2010 sedan
Yaris sedan tire sizes
Hello. If my Yaris takes a 185/60R 15 tire size, would I also be able to use a 195/65R15. I have some good spares
maxifam is offline   Reply With Quote
Old 06-29-2020, 07:50 PM   #2
Not really. Tire would be quite tall.
185/60 means height of sidewall is 60% of the tires 185 width. Apply same math to 195/65 and you'll understand how much bigger than stock the tire would be.
You can do it, they will physically fit. Just understand that your speedometer and odometer will no longer be accurate.
Old 06-29-2020, 10:38 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
I wouldn't install such tall rubber.
185/60/15 = 23.7" diameter
195/65/15 = 25.0" diameter
Old 07-02-2020, 03:07 PM   #4
billfires
Drives: 2010 3dr LB
I have a set of 195/65-15 tires that are on stock steel wheels that I run in the winter months. These are on a 2010 3 dr HB with a manual trans. They are noticeably taller but still are acceptable. I don't think you would want to tow a trailer or have 4 large adults in the car. The most noticeable change is in the spring when the 185/60-15 tires on aluminum rims are put back on, the performance difference is substantially better. Bill C
billfires is offline   Reply With Quote
Toyota ending Yaris Hatch & Sedan production for United States by end of June ferio252 Third Gen Yaris General Discussion 16 07-05-2020 12:53 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 83 05-07-2011 11:03 AM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
