Old 07-24-2017, 10:48 PM   #1
bluefever00
Drives: 2008 Sedan
Blower motor removal
I've tried searching and the search engine can't find anything. I also have looked through the diy's. I am new to the forum, just bought an 08 Yaris 4 door sedan. Can anyone tell me how to remove the blower motor? It is creating quite a ruckus and doesn't seem to be blowing fast at all.
bluefever00 is offline   Reply With Quote
Old 07-25-2017, 06:37 AM   #2
alanwagen
3 SCREWS
It is very easy to get to. It it under the glove box side and the screws are accessible. One electrical clip and 3 screws and it's out. You can get a new one at Amazon for around $50 bucks. At the store, over $100. It looks a lot like this but easier to do because there is less junk under your dash.
https://www.youtube.com/watch?v=hqhxNVaGcYU&t=231s
Old 07-25-2017, 03:35 PM   #3
Big James
Drives: 2008 Toyota Yaris
bluefever, I may be replacing my blower motor as well. What issues have you encountered?
There seems to be no air coming from my AC or heat at this point.
I have read that fuses could be an issue. Should I check these prior to replacing the blower motor?
Thanks!
Big James is offline   Reply With Quote
Old 07-25-2017, 03:38 PM   #4
alanwagen
Thanks!
Check the fuses first but these motors will gunk up and lock up. Funny, sometimes they will start if you slap it a few times while set up on high.
Good luck.
Old 09-10-2017, 03:26 PM   #5
bluefever00
Drives: 2008 Sedan
does anyone possibly remember what type of screw it has? I tried a large flat-tip, didn't have any luck with it. Sorry about the picture, the best one I could get, flash distorted it, looks like someone was already in there.
Old 09-10-2017, 07:48 PM   #6
bluefever00
Drives: 2008 Sedan
Figured it out, it's a T20. Very quick, easy job!!!! Easiest i've ever done i think!!!! Now she blows air like crazy and my dad's happy as heck,lol!!!!
Old 08-07-2020, 11:35 AM   #7
beowulf
Drives: 2008 3dr hatch, 1.5L, 5-spd MT
Thanks for posting the size of the bit to fit the screws. Saved me the trouble trying of trying to figure it out.
beowulf is offline   Reply With Quote
Old 11-08-2023, 12:41 AM   #8
rayfloyd170
Drives: Yaris 2016 1.3 Manual
This is related info for yaris gen 3 denso blower repair. This motor can be repaired endlessly since all parts are readily available in the market.
Common reason why it makes noise is due to worn out brush or uneven surface of the commutator due to wear and tear.
https://www.yarisworld.com/forums/sh...657#post843657
rayfloyd170 is offline   Reply With Quote
Blower only works on LOW spookybathtub DIY / Maintenance / Service 4 03-10-2017 12:14 PM
Intermittent (old and new) AC blower motors RiggYaris DIY / Maintenance / Service 5 03-14-2016 06:09 PM
Interior blower fan dead...blowing fuses. phyrefighterjay General Yaris / Vitz Discussion 23 07-27-2015 10:34 AM
Water leaking from blower motor when ac is on borikuaa DIY / Maintenance / Service 1 07-05-2015 10:46 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
