Old 01-07-2022, 10:29 PM   #1
Heidek09
Drives: 2011 Yaris
Question Abs engaging
I have a 2011 Yaris that abs engages when I firmly press down the brake on dry roads. I took out and cleaned the ABS sensors and put them back in and still got the same results. Anyone have an idea on what else it could be?
Heidek09 is offline   Reply With Quote
Old 01-08-2022, 08:59 AM   #2
ex-x-fire
If you're hitting the brakes firmly then are you near the point of lock up? It is winter in Wi after all.
Old 01-08-2022, 12:15 PM   #3
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
Your tires can still lose traction on a dry road. Also a lot to due on how old your tires are.
alanwagen is offline   Reply With Quote
Old 01-09-2022, 09:28 PM   #4
Heidek09
Drives: 2011 Yaris
Much appreciate it, I just felt that abs engaged to easily when compared to my civic.
Old 07-01-2022, 03:15 PM   #5
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Mine has always had the premature abs problem. In the snow, it is worse.
My old Echo was a much better car.
Tags
abs, abs sensor, braking
ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right Chwbcca DIY / Maintenance / Service 5 09-15-2021 08:16 AM
Abs engaging at low speed Mike003 DIY / Maintenance / Service 10 08-20-2019 03:37 PM
First Generation Vitz ABS Issue Owais Yunus DIY / Maintenance / Service 0 10-29-2016 11:14 AM
Noise From ABS when Braking + ABS & (!) Light On - Please Help Chris Jackson DIY / Maintenance / Service 2 04-23-2016 12:00 AM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
