11-09-2021, 02:17 PM | #1 |
Drives: 2007 yaris HB Join Date: Mar 2016
crack wheel well drivers side rear...
It looks wet because I sprayed with some rust inhibitor.
Its very solid and no flaking or anything like that. Its a seam that appears to have opened up.. |
01-27-2022, 09:27 AM | #2 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Probably just the rubber shrinking. I wouldn't worry about it unless you can see inside the car through it
01-27-2022, 09:39 AM | #3 |
Cant see through it..
not too concerned ...I was just curious if its common? Thanks |
01-30-2022, 03:19 PM | #4 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
i dunno if its common to the yaris but its common to alot of cars, most guys just never notice, "if" your concerned about it, chip out as much as you can and re-coat the area with seam sealer
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Rust - Sill and rear wheel well | jansen.fan | DIY / Maintenance / Service | 20 | 01-07-2019 10:54 AM |
Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
