04-23-2021, 04:20 PM | #1 |
Drives: yaris Join Date: Apr 2021
suspension arm rusted
Good day,
Can someone identify this part (see picture attached ) and tell me if it's fixable? It is a Yaris 2008 with 292000 KL. Nothing else is rusted. Mechanic A1 Thank you for your help Last edited by pearlyne; 04-30-2021 at 03:43 PM. |
04-24-2021, 03:52 PM | #2 |
Drives: 2008 Yaris RS Join Date: Feb 2021
Hi Les here. This appears to be a corrosion issue of the floor pan. My advice would be to take it in to a reputable auto body shop and have them look at it. Or to a Toyota dealership and have them look at it. The last thing you want is the arm to detach whilst driving.
04-25-2021, 08:53 AM | #3 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
That is not a removable part, it is part of the unibody.
Unfortunately it also strengthens the attachment point of the rear axle beam. That would be a tough area to weld in new metal as it has a lot of tight curves. I'm sure there is a shop that could do it, I'm just not sure it would make sense financially. IMO the dealership is not the right place to have this looked at and fixed
No one ever wants to give a Yaris the point by... |
04-25-2021, 05:45 PM | #4 |
DIY repair if that area happened here
https://www.yarisworld.com/forums/sh...ad.php?t=62787
Tags |
supension |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Changing Rear Wiper Arm | barfart | UK | 6 | 04-24-2021 11:41 AM |
Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
'02 Echo Suspension clunk fix | tmontague | DIY / Maintenance / Service | 5 | 06-29-2015 11:02 AM |
Left lower suspension arm rear bolt broken. | Kramruuk | DIY / Maintenance / Service | 1 | 07-07-2012 05:42 PM |
NSW Proposed Suspension Restrictions | Bella | Australia | 0 | 09-22-2010 01:51 AM |
