Old 12-02-2020, 10:38 AM   #1
N14ParkwayRacer
Drives: 2008 Toyota Yaris
2008 US to UK instrument cluster swap
Hello everyone, I need some info. I own a 2008 Yaris 1.5 hatchback in the USA with no tachometer. I bought a 2008 Yaris 1.8 SR cluster off of eBay from the UK with a tachometer. When I installed it everything works except the speedometer. I checked all the wiring & even used my Snap On scan tool to check the speedometer through the CAN network & it works fine. Does the speedometer need to be reprogrammed for my car or am I missing something silly. I can’t find anything about reprogramming it online. Any help would be appreciated.
Thanks in advance.
N14ParkwayRacer is offline   Reply With Quote
Old 12-03-2020, 02:56 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I was able to swap to a US cluster with a tach and didn't have to change anything. My '09 uses a turbine sensor on the transmission for the speedo signal, not the ABS/CAN signal (afaik). Take a look at the 2ZR swap threads, specifically where they show adding the turbine wire harness to the engine fuse box to see if you have those wires/signals.
Vitz 2008 Instrument cluster connectors pinout help needed osse In Car Entertainment + Electronics (audio / video / alarm) 4 10-15-2020 02:37 PM
3rd Gen Gauge Cluster Swap :D KenTK808 Third Gen Yaris General Discussion 22 10-21-2017 07:58 AM
Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback AndyW Willing to Buy by private party 6 12-07-2014 08:53 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
