03-05-2020, 01:19 AM | #1 |
Drives: 2009 Yaris, 1994 HiLux Surf Join Date: Nov 2013
New clutch, car is abysmal to drive
We have terrible repair shops, privilege of living in a third world country. When you go to one with a problem, you leave it with ten other new problems.
My 2009 Yaris has more than 160,000KMs on the odometer. It has been running almost flawlessly since I bought it with about 100,000KMs on it 3 years ago. Recently it started to make a faint rubbing noise whenever I engaged the clutch. Right of the bat I understood it must be a release bearing issue. As the days passed the noise became a loud screeching noise. Gear changes became awkward, especially in traffic, since the noise it made drew everyone's attention. I knew how to do a clutch job, but I didn't have the time or the tools (power tools really) to do the job at home. So I took it to a shop. I got myself 'OEM' parts for it (this is a hit or miss in my country, what's usually branded as OEM is some Chinese rip off). New pressure plate, new clutch disk and a throw out/release bearing. Sure enough the old release bearing was a toast. It was in pieces. I have noticed that the old pressure plate had more smaller springs while the new one had fewer but bigger/wider springs. The old clutch disk had four damping springs, and the new one had three. I didn't care much about this because this was probably a transmission that's used by a lot of other Toyota models throughout the years and there might be subtle changes. "As long as it fit right, there shouldn't be a problem," I thought. The new parts were swapped in and while at it, new gearbox oil as well. I didn't notice much on my way back home since I was exhausted. The only thing I noticed was how light the clutch pedal felt. I thought this was due to the fact that the mechanism was cleaned and greased before being put back in. But this morning, I noticed that 1st gear and second gear are sort of difficult to shift into. The biting point for the clutch is also unpredictable. Sometimes it bites as soon as I start lifting my foot, sometime it bites midway. Gear shifts have this unsettling snap to them. It feels like you won't get it back out of that gear. Now I don't know if any of this is normal (I hope its not). The old clutch was such a delight to drive. Apart from the noise it started to make at the end, it was very smooth. Gear changes required minimal effort. There are a lot of things going in my head. Maybe they left the pressure plate bolts loose, or its not tight enough (I don't know why I didn't take my torque wrench to the shop). Maybe the so called OEM parts are not so OEM, and its just a weak pressure plate. Maybe the oil they used is a bad quality and its just making things worse. Sorry for the morning rant. I just want someone to explain what might be going on here. Thank you, P.S: A couple of things about the shops here. No concept of torque wrench. No concept of clutch alignment tool (he was surprised when I told him about it while he was aligning the clutch by hand). No concept of engine variants and engine swaps.
The Surf is still here.... But now there is a Yaris next to it! |
03-05-2020, 07:14 AM | #2 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
That has a slave cylinder, maybe try bleeding it.
03-05-2020, 03:36 PM | #3 |
Yaris Hybrid Limited 2015
Probably wrong gear Oil, you have to use a single grade 75w gl4 oil.
Or Else you get bad shifting, not long ago there was another tread about it with one from Eastern Europe. He wouldnt believe it, But had to admit it was the cause to bad shifting when he Got the correct Oil in the gearbox. http://www.yarisworld.com/forums/sho...&highlight=Gl4 You are probably best of going to a Toyota dealer and buy the gear Oil. It is this one. https://www.ebay.co.uk/itm/Genuine-T...-/323352225069
03-10-2020, 02:46 AM | #4 | |
03-10-2020, 04:39 PM | #5 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
First things first you need to bleed your brakes and clutch system, see how that works out, next if that doesn’t help, I would make sure your flywheel has been machined when you put the clutch in, if you didn’t, well, you gotta do it all over again. If that doesn’t help, I would replace the clutch slave cylinder with an OEM part, and then lastly... your synchronizer are going out... but that’s hopefully not it or else you have to take the transmission apart to do it.
Tags |
1kr, clutch, yaris |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
What do car brand representatives actually drive? | scratchpaddy | Off-topic / Other Cars / Everything else Discussions | 7 | 11-27-2016 05:01 PM |
Gwasabi (Yoshi) - Photo-Scavenger Hunt! | gwasabi | Photo-Video-Media Gallery | 24 | 03-07-2009 11:23 AM |
Jerkratt - Photo Scavenger Hunt | Jerkratt | Photo-Video-Media Gallery | 3 | 03-04-2009 09:03 AM |
YAR1S - Photo Scavenger Hunt! | YAR1S | Photo-Video-Media Gallery | 4 | 03-02-2009 07:44 PM |
