Old 07-06-2022, 02:24 AM   #1
daewoo01
2NZ Echo kids comp hack
Drives: 2003 Toyota Echo comp hack
(NCP10/13) Air Flow Meter - Any option to increase size with standard ECU
Using the rough formula of needing 1mm/Hp/cylinder inlet pipe diameter for power, the standard AFM at 55.5mm (2ish inches) would max out at barely a couple of percent above standard.
e.g. 120Hp = 30Hp/Cylinder, requires the equivalent of 4 x 30mm Diameter inlet size.
to get to a modest 20% increase - 130Hp (through other mods) would require the AFM to be 65.5mm diameter to supply enough air. 10mm increase over the standard size.
Just increasing the inlet pipe size would make the AFM signal the ECU that it was receiving 45% less air that it really was, running ultra lean and boooom!!!
Is there a way to swap or modify the AFM so that the ECU supplies the correct amount of fuel for actual airflow as performance mods allow?
Maybe adding a resistor in the circuit, but I fear this would destroy idle.
I am looking to add a quad throttle body system, but continue to use the standard ECU. I understand sacrifices would be made.
daewoo01 is offline   Reply With Quote
Old 07-06-2022, 02:58 PM   #2
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
No, the stock ecu cannot be fouled
Car won't run right with a bigger inlet pipe
ITB's on stock ecu ain't going to happen either.
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 07-07-2022, 07:46 AM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Not happening with a Toyota ECU.
If you want to be able to mess with ECU tuning, invest in a good standalone or piggyback.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 07-22-2022, 10:10 PM   #4
speedworxs
Drives: |Mr2
While it may be similar, on the mr2 groups they do what is called the MAF mod. On the 1zz (which uses almost the exact same system as the 1nz) they space the MAF a 1/4" higher to trick the engine to readjust ignition timing and fuel. That was on a slightly larger intake pipe, but I imagine you could experiment with it ... Ps, I'm not responsible
speedworxs is offline   Reply With Quote
Toyota Yaris part# 21-573 yarispro Central and South America 40 08-15-2007 02:51 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
